Re: AFB Question
[Re: 62maxwgn]
#906919
01/17/11 11:30 AM
01/17/11 11:30 AM
Posts: 1,565 tennessee
pushbutton
tennessee
65 426 street wedge,not sure on the cfm's without looking.
Anybody know a source for AFB cfm's?
Re: AFB Question
[Re: pushbutton]
#906920
01/17/11 03:58 PM
01/17/11 03:58 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Regardless of the numbers you'll hear, the fact is Carter never published cfm ratings for OEM carbs. I'd guess the AFB's used as singles back then were well under 600 cfm.
Re: AFB Question
[Re: quickd100]
#906922
01/18/11 01:57 AM
01/18/11 01:57 AM
pushbutton
tennessee
Here's the venturi dia. and CFM ratings for AFB's.
primary venturi,1-1/8 secondary venturi,1-1/4, 400cfm
pri. venturi, 1-3/16 sec. venturi 1-1/4, 500cfm
pri. venturi 1-1/4 sec. venturi 1-9/16 575cfm
pri. venturi 1-3/16 sec. venturi 1-9/16 625cfm
pri. venturi 1-7/16 sec. venturi 1-9/16 750cfm
Hope this helps. Dave
Thanks will measure
