Re: building 360, need cam advice
[Re: dughuff]
#906771
01/16/11 08:15 PM
01/16/11 08:15 PM
Posts: 5,167 CT
GTX MATT
CT
I would return them just because of the fact that being dished stock replacements your compression ratio will likely be in the 7s. That cam isn't really big, but it would really like more compression for more low end response but it would work. It really depends on your gearing and torque converter. In my opinion under 8 to 1 compression isn't good no matter what cam you run.
[Re: 2boltmain]
#906773
01/16/11 08:23 PM
01/16/11 08:23 PM
Posts: 375 NE Oklahoma
71valiant
NE Oklahoma
I built the same motor. Stock block, 292/292 duration 484/484 lift. 230@.050. Headers, RPM airgap intake, I cleaned the heads up. Stock mopar ignition, holley fuel pump 4:30 gears and a 2600 stall converter. It runs well for what it is. I like the motor for what I built it for money wise.
[Re: dughuff]
#906777
01/16/11 09:24 PM
01/16/11 09:24 PM
Posts: 1,629 wilmington,ohio
ohiodemon
wilmington,ohio
i used the kb-107's in my 360.with stock unmilled heads you will be around 9.3-9.7cr. those pistons worked great.Pay attention to the ring gap assembly instructions. stock valves will be fine. some 3.91 gears would help too ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 451Mopar]
#906780
01/16/11 10:14 PM
01/16/11 10:14 PM
RapidRobert
port em as far as you dare (they are expendable stock heads)/have your shop add 2.02's & unshroud the combustion chambers/bowl hog the bowls. dulcich has some excellent SB porting articles which might be avail on the Mopar Muscle archives
[Re: dughuff]
#906781
01/16/11 10:51 PM
01/16/11 10:51 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi keep the 1.88 valves . get the flat top pistons . my son has a similar combo in a duster . 360,small cam ,headers,3' exhaust , ld340 intake , 750 vac holley ,727, 3.55 gear, runs 13.8 consistantly ! ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: dughuff]
#906782
01/16/11 11:44 PM
01/16/11 11:44 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Slow down and do more research before dropping your $$$ down. You don't want to go off "half cocked", then be very unhappy with the results and $$$ down the drain. No sense in 2.02 valves on the street usually. If it is usually running 4500 rpm or less, 1.88 valves will be fine. Save your money for elsewhere. Don't say what trans you are running. If automatic, you will be much better spending money on a better converter than on big valves. If you rush and throw something together half arsed, you will be wasting money and leaving performance on the table. Carefully, patiently, get a plan together, then you will be happy with the results. ![](/ubbthreads/images/graemlins/thumbs.gif)
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: MoparforLife]
#906786
01/17/11 10:30 AM
01/17/11 10:30 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
KB107's, comp XE268, comp #901 springs and matching retainers, and leave the 1.88's unless your valves are severely sunk...if the heads need more than a valve job (if they need new guides or valves, etc), I'd buck up the extra $$ and buy these headsgranted, stock dished pistons, headers, and a comp XE262 will get you into the high 13's/low 14's and run fine on 87 octane.
[Re: dughuff]
#906787
01/17/11 10:41 AM
01/17/11 10:41 AM
Posts: 2,177 ill
dennismopar73
ill
being i built this very same motor,, put it in a 4000# boat,, street car drove everyday with a smaller cam, 270 h comp, it ran best of 14.22, with 391,gears with stock heads, and what everyone said was junk intake a torker 360, and a 600 holley carb mmmm so in somthing thats lighter than 4000# little bigger cam, bigger carb, low 13s high 12 now prob easy!!!!
[Re: dennismopar73]
#906788
01/17/11 04:08 PM
01/17/11 04:08 PM
Posts: 5,270 Missouri
MY340
Missouri
My 360 motor is a PAW shortblock, 9:1 final compression with rebuilt 1.88 /1.60 heads, Comp 280H cam, Weiand Stealth manifold, Hooker headers and 750cfm Eddy carb. 2600 stall convertor with 3.91 gears. Combo pulls strong thru all rpms ranges. ![](/ubbthreads/images/graemlins/drive.gif)
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: MY340]
#906789
01/17/11 04:30 PM
01/17/11 04:30 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
#3400 kb's 9:1 xe284 and eddy heads,rest of block is stock air gap,headers,700 cfm,converter and 3:73's does low 12's on street tires all day long. shootin for 11's but prob won't get there without spending more money. ![](/ubbthreads/images/graemlins/wrench.gif)
