Re: building 360, need cam advice
[Re: dughuff]
#906734
01/16/11 07:45 PM
01/16/11 07:45 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Do you have rods? I have stock rods, if I can remember what I did with them, and a set of new H rods.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#906735
01/16/11 07:48 PM
01/16/11 07:48 PM
amxautox
You shouldn't bend the valves unless you over rev the engine and hit the valve with the piston. You shouldn't bend the pushrods unless there is coil bind, so check the valve spring set height, compressed height, carefully.
Tom
author unknown
[Re: dughuff]
#906737
01/16/11 08:10 PM
01/16/11 08:10 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
You should repost this over in the Q&A section, LOTS of knowledge over there. They can educate you on static and dynamic compression ratio, quench, and cam compatibility. IMO, with this cam and compression ratio you're not going to have much low end. They'll also need to know what you're doing with the heads. IIRC, the 1.88 intake valve provides some fuel economy and low end (driveability) power benefits? If you need more flow the FI 360 heads are some of the best traditional small block heads out there until we start talking magnum heads? Someone correct me if I'm wrong here. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 340SIX]
#906740
01/17/11 11:02 AM
01/17/11 11:02 AM
Posts: 2,177 ill
dennismopar73
ill
man what the heck is a 3/4 cam??hahahah havent heard that in years,,, those where just slightly over stock,, ok they were stock!! used to hear that on guys with 340 motors,, "yeah man i got one of those three quarter cams in there sure does run good" brought back memories!! hahahalol
[Re: MoparforLife]
#906742
01/17/11 12:09 PM
01/17/11 12:09 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
on the heads, your best/cheapest bet would be to get the EFI magnum heads out of the junkyard from any V8 truck. much better flow, and performance in stock form. just have to get hollow pushrods and oil through lifters, cause the magnum heads do not oil through rocker shafts like LA heads...infact, they don't even HAVE rocker shafts!! (part of whey they're so much better, slightly offset rockers to give better intake runners for airflow)
**Photobucket sucks**
[Re: dughuff]
#906744
01/17/11 11:44 PM
01/17/11 11:44 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
I'm ready to start assembly of a 1976 360 block for my 71 Demon. Got it punched 30 over and bought stock dished pistons which are only rated at 8 to 1 compression. I wonder if I made a mistake there, since I bought a summit racing cam with 284 advertised duration (228 @ .050).
This engine will be pretty much stock except for the cam, double roller timing chain, and hi volume oil pump, so I'm worried about the lumpy cam I bought. I read that I should be going with 9 to 1 compression with this cam. Am I going to bend my valves or pushrods? Should I exchange these pistons before its too late?
I'm building this engine for street use. Of course I want good power but it doesn't need to be super fast. A 14 second qurter would be nice. I've got an aluminum intake and 4 bbl Holley for the top.
Any suggestions are appreciated! This is the first v8 I've built myself.
Also - I'm getting the heads redone: Is it worth the extra money to get the intake valves widened to 2.02? They are stock 1.88 right now.
8 to 1 compression isn't going to cut it with this cam. 9 to 1, is more realistic. The compression you now have would make decent power with a cam closer to the 340 cam specs. If you decide to ditch the "lumpy" cam, you may need to make a few KEY adjustments to the engine with a "smaller" cam. Yes, the intakes CAN be widened to 2.02. It, will benefit you later on, IF you decide go back with the higher compression and "lumpy" cam. But for now, weigh the price of new 9 to 1 pistons, rings and prep work AGAINST a complete cam kit (preferably around 215-220 degrees @ .050 on the intake) for your engine. BTW what kind of intake manifold and size of Holley carb?
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: HYPER8oSoNic]
#906745
01/17/11 11:55 PM
01/17/11 11:55 PM
Posts: 20,570 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
8.1 = too low for anything other than a stock type cam.
Do you really know that is what the compression ratio is? Have you measured the piston dish volume, how far the pistons will be down in the bores, the true combustion chamber volume of your heads, etc? Are you having the block deck surface cut down, milling the heads, running a thinner gasket?
There is a handy compression ratio calculator on the KB Pistons website to help you figure out what your compression ratio is.
[Re: Neil]
#906746
01/18/11 12:50 AM
01/18/11 12:50 AM
HYPER8oSoNic
Desert Tracker
Great points, but according to Dughuff, he wants a street car capable of running a solid 14-sec quarter. Sounds to me like a "well tuned" stocker setup!! A bit of "340 type" hardware will get the job done for a little less than what he thinks. And on his CURRENT compression too!!
[Re: HYPER8oSoNic]
#906747
01/18/11 01:57 AM
01/18/11 01:57 AM
Posts: 2,177 ill
dennismopar73
ill
compression wont bother that cam not rocket science here ive put that motor together 4000 # car 391 gears , header STOCK HEADS torker 360 intake nothin converter 600 holley and run 14.20s drove it everday to work COME ON !!!! wish i had 3200 car to put it in built that back in 1992 75 road runner car still going , same motor!! run low 13 high 12 easy
[Re: HYPER8oSoNic]
#906749
01/18/11 02:50 PM
01/18/11 02:50 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
the other post he started has more technical discussion and suggestions, but realistically to be a solid 14 second car with (I presume) 3.23's or so, a stock long block 360 with a 600 cfm carb, eddie air gap, headers, a factory high stall converter or MP166K converter and a comp XE262 will get you there in an A body and be happy as a clam on 85+ octane...fuel economy won't be the best though.
[Re: patrick]
#906750
01/18/11 09:37 PM
01/18/11 09:37 PM
HYPER8oSoNic
Desert Tracker
I believe with a BIT of ignition/carb tuning, he WILL have decent gas mileage. The KEY is to make the parts compatible to work TOGETHER!!
