Re: 440 build noise Help!! [Re: stumpy] #90667
07/20/08 07:20 PM
07/20/08 07:20 PM
Back the tining off a couple of more degrees.
i would fatten up the jetting before knocking out more timing.
Re: 440 build noise Help!! #90668
07/20/08 07:43 PM
07/20/08 07:43 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Is it possible to go too far on the timing? I will stop tomorrow after work and buy a timing light with advance. What is the absolute max timing ? 36??? Alex
Re: 440 build noise Help!! [Re: Alexdodge] #90669
07/21/08 08:35 AM
07/21/08 08:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what do you think your compression is? 36* shouldn't be too bad. You should also fatten your carb up? what kind is it?
Re: 440 build noise Help!! [Re: Alexdodge] #90670
07/21/08 10:22 AM
07/21/08 10:22 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
yes it is , you need to bring the RPM up to make sure its not still advancing .
what era is that mopar dist ? a recent buy , last 2 -3 years or an old one ? the new ones have an adjustable mechanical advance , the old ones do not .
right now you need to set total and worry about inital when you can adjust the mechanical somehow .
also you need to do something about the fuel , either use an electric pump to get at least half if not more of the tank out and then refill with 93 or start driving the wheels off to burn it up .
Re: 440 build noise Help!! [Re: JohnRR] #90671
07/21/08 09:43 PM
07/21/08 09:43 PM
Eastern ohio
Eastern ohio
Today I put in at least 10 gallons of 93 octaine, hooked up the new digital timing light with advance and brought the engine up to 2500 rpm and checked the timing. It came in exactly at 36*. This amazed me because I had set it by measuring 2 1/4 inches from the factory mark, like another Moparts member suggested. Didn't get to try it on the road with the 93 gas due to a meeting I had to go to. Hopefully tomorrow!
The carb is a edlebrock 800cfm and the distributor is about 7 months old. Someone asked about these items. Thanks all, Alex
Re: 440 build noise Help!! [Re: Alexdodge] #90672
07/22/08 07:55 AM
07/22/08 07:55 AM
JohnRR Offline
JohnRR  Offline
Sounds good , but as a test bring the RPM up to 3000-3500 and see if its still at 36 or has gone higher
Re: 440 build noise Help!! [Re: Alexdodge] #90673
07/22/08 09:11 AM
07/22/08 09:11 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Are you sure the noise is coming from 'inside' the engine, and that it's not something like the fanblades are hitting the shroud or radiator when the engine torque's in it's motormounts when you put the power on?
