5.7 question #906034
01/16/11 12:13 PM
01/16/11 12:13 PM
Canada
shadowauto Offline OP
Canada
can I take the head from a 2009 VVT 5.7 and install them on a 2004 truck 5.7 and what about the rest of the parts except the cam do they interchange thanks also who make a motor plate for a 5.7 motor .
Re: 5.7 question [Re: shadowauto] #906035
01/16/11 12:48 PM
01/16/11 12:48 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Yes and no. The head is 20cc smaller, so compression rises to 11.6. You will also need custom pushrods and an intake with 6.1 size ports.
Re: 5.7 question [Re: BergmanAutoCraft] #906036
01/16/11 04:58 PM
01/16/11 04:58 PM
Canada
Canada
so you tellihg me that if I use the 09 heads my compression will be over 11 to 1 this is to much compression for the gas they sell today I will like to be around 9.2 at the most intake is no problem I will buy a MOD MAN with six pack carb so the pushrod in the 09 will not work who sell custom push rod also i will need ticker head gasket that shound be a problem I want to install this motor in my 72 duster thanks for the advice .
Re: 5.7 question [Re: shadowauto] #906037
01/17/11 12:17 AM
01/17/11 12:17 AM
Long Island, NY USA
Long Island, NY USA
Compression will need to be dropped. A custom head gasket is the easiest choice. Custom pushrods have to be measured and ordered from a custom pushrod place, such as the Pushrod Factory. The 09 pushrods will not work. Are you sure the mod man fits under the hood?
