a body barracuda 68 #905970
01/16/11 10:36 AM
01/16/11 10:36 AM
nice france
N
nico06 Offline OP
nico06  Offline OP
N
nice france
hello i found a wilwood front disc brake 140-2723-B does it fit on the original steering knuckle because i want to change the bolt pattern 4" to 4.5" ! somebody did it before ? OR have an idea i juste want to change calipers and disc brake.
thank you
plymouth barracuda 340ci formula S convertible auto 1968
Re: a body barracuda 68 [Re: nico06] #905971
01/16/11 10:58 AM
01/16/11 10:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What are the brakes that are originally on the front of your car ? The wilwood setup I am pretty sure is made to fit on a spindle that was used for 9" drum brakes .
Re: a body barracuda 68 [Re: JohnRR] #905972
01/16/11 11:01 AM
01/16/11 11:01 AM
nice france
N
nico06 Offline OP
nico06  Offline OP
N
nice france
originaly i have kelsey hayes calipers an 11"04 disc brake !
Re: a body barracuda 68 [Re: nico06] #905973
01/17/11 02:57 AM
01/17/11 02:57 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Check out the SSBC brake kit that uses the aluminum K-H look-a-like calipers. They have a rotor that looks like the 65-67 Mustang rotor with a bearing spacer..........
