Correct '70 Cuda Part Numbers ??? #905951
01/16/11 07:23 AM
01/16/11 07:23 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Can someone tell what the correct part numbers are for a '70 Cuda headlight harness and also for a '70-1 Cuda rear window louver install kit? This would be the package that contains the pins,washers,cables,etc.Thanks for ant help!!
Re: Correct '70 Cuda Part Numbers ??? [Re: 44D6PAKCUDA] #905952
01/16/11 03:58 PM
01/16/11 03:58 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Wiring Harness Numbers
Re: Correct '70 Cuda Part Numbers ??? [Re: 44D6PAKCUDA] #905953
01/16/11 04:01 PM
01/16/11 04:01 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I would have to check an original to be 100% sure but the parts book looks like it shows 2983492. Not sure if this is it or Snoopy's above is the wiring harness in question....kinda confusing in the book.
Re: Correct '70 Cuda Part Numbers ??? [Re: FJ5_Fish] #905954
01/16/11 04:11 PM
01/16/11 04:11 PM
Snoopy Offline
Snoopy  Offline
I think FJ5_Fish is correct.
Rear Louver Part Numbers
Re: Correct '70 Cuda Part Numbers ??? [Re: Snoopy] #905955
01/16/11 04:17 PM
01/16/11 04:17 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I was going to post the same page as you and then I flipped the page saw the other one and threw a hail Mary!
Re: Correct '70 Cuda Part Numbers ??? [Re: FJ5_Fish] #905956
01/16/11 06:43 PM
01/16/11 06:43 PM
Thanks Snoopy and Jim.The page with the headlight harnesses is missing out of my parts book,so thanks for posting that.On the louvers,is the first line that says louver package,the complete install kit or it that number for the louvers and the install kit?I saw a install kit on eBay one time but never wrore down the number.Thanks
Re: Correct '70 Cuda Part Numbers ??? [Re: 44D6PAKCUDA] #905957
01/16/11 08:38 PM
01/16/11 08:38 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Jim - Just take all the numbers to your local dealer and see which one is the most expensive....
