Re: What cars & trucks have 11in rear drums from for 8 3/4.
[Re: Blakcharger440]
#905843
01/16/11 03:00 PM
01/16/11 03:00 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
My 68 RR has 11" rears, its a power disc brake car
Then someone swapped them on there, the factory installed the wrong rear end assembly or it's not an original disc car because it's supposed to have 10" drums on the rear ....
Hey JohnRR. Are you saying that most all Dodge & Plymouth B bodies if equipped with power disc brakes would have had 10in drums?
Up until and including 1970 , not sure what they did after that .
[Re: Exit1965]
#905844
01/16/11 04:37 PM
01/16/11 04:37 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Ok, I remembered I had these shots, I snapped some pics of the van I yanked the parts off of, to make it easier to shop for replacements:
That looks like ROCKLIN Pick-n-Pull.
[Re: JohnRR]
#905845
01/16/11 04:53 PM
01/16/11 04:53 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Rear drum sizes 65-68 C bodies.Drums were smooth-finned after 1969. Fury with /6,318 11X2 All C's with 383,440's 11X2-1/2" Tow packages 11X3" drums BOTH FRONT AND REAR (non self adjusting shoes). All C wagons came with 11x2-1/2 with any engine,except when ordered with towpackage. The different widths in drums require the matching backing plates. Hope this helps.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: gtx69]
#905848
01/16/11 10:28 PM
01/16/11 10:28 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Why not call them and ask about the drums and hardware?
Do I ask for 68-70 Bbody rear drum brake 11inch hardware?? I thought the B-bodies had 11x2.5 brakes and not 11x3???
What year and type of vehicle would I reference for the hardware to fit 11x3 backing plates?
[Re: JohnRR]
#905849
01/16/11 10:39 PM
01/16/11 10:39 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Same for 71-4B's except this 72 wagon I just parted is the first 71-4B with disc and 11" drums I've seen.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
