What cars & trucks have 11in rear drums from for 8 3/4. #905822
01/16/11 12:14 AM
01/16/11 12:14 AM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I need a set of 11 inch rear drums for a 8 3/4 rear. What cars and trucks came with those?
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: Blakcharger440] #905823
01/16/11 12:18 AM
01/16/11 12:18 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I got mine from a Tradesman Van (b200 maybe?), circa 1974? if I am remembering right. I yanked the stuff off at a junkyard.
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: Exit1965] #905824
01/16/11 12:25 AM
01/16/11 12:25 AM
Cleveland, OH
fury413rb Offline
fury413rb  Offline
Cleveland, OH
my 67 fury does
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: Exit1965] #905825
01/16/11 02:47 AM
01/16/11 02:47 AM
Under My Car
Mopar_Country Offline
Under My Car
That's a real good place to look, the older b vans, my old b van had one.
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: fury413rb] #905826
01/16/11 02:49 AM
01/16/11 02:49 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Big block Charger/ Roadrunner came with 11 inch rear drums, when all 4 wheels used drum brakes.
C body with 4 wheel drums also used 11 inchers...
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: sthemi] #905827
01/16/11 02:54 AM
01/16/11 02:54 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My 68 RR has 11" rears, its a power disc brake car
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: ademon] #905828
01/16/11 04:17 AM
01/16/11 04:17 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Just parted out a 72 Coronet wagon. Disc with 11" drums. Think its a 1st for me with 71-4B's anywho.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: moparmarks] #905829
01/16/11 06:41 AM
01/16/11 06:41 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Trucks will often have what you need. The 8.25, 8.75 and may if not most 9.25 axles in older trucks use the same 5 bolt flange on the backing plates. Nice, huh?
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: Kern Dog] #905830
01/16/11 10:27 AM
01/16/11 10:27 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Ok, I remembered I had these shots, I snapped some pics of the van I yanked the parts off of, to make it easier to shop for replacements:
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: Exit1965] #905831
01/16/11 10:37 AM
01/16/11 10:37 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
65-68 D100 trucks came with 11x2 rear drums. So did the 61-64 trucks but they had the tapered axle.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: ademon] #905832
01/16/11 10:53 AM
01/16/11 10:53 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Then someone swapped them on there, the factory installed the wrong rear end assembly or it's not an original disc car because it's supposed to have 10" drums on the rear ....
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: JohnRR] #905833
01/16/11 11:29 AM
01/16/11 11:29 AM
scratchnfotraction Offline
I used 11x2.5 from a 73 newport 8 3/4
I have used 9 1/4 truck BB&drums also on the 8 3/4
my 72 4x4 truck 8 3/4 has the big 5 on 5.5 wbp with 11x2 brakes
i used some 10s from a 8 1/4 on the 8 3/4 also
any mid 80s truck with 8 1/4-9 1/4 would be good for that size
any of the mid 80s R-body cop cars will have the 11x2.5
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: JohnRR] #905834
01/16/11 12:31 PM
01/16/11 12:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
It's a disc car, maybe someone swapped it, stops nice!!
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: ademon] #905835
01/16/11 12:50 PM
01/16/11 12:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I agree...
My 71 challenger came with power 4 wheel drum brakes with 11" in the rear.
I installed power disc brakes on the car with the 11" in the rear and it has awesome stopping power now. So does my 74 with 10" drums in the rear.
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: ademon] #905836
01/16/11 01:04 PM
01/16/11 01:04 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Be aware that a lot of people don't know how to measure drum-diameter the proper way.
I've received a pair of 10" drums once whichh were advertised as 11" just because the clown-PO just put a tape measure to the drum and measured the OD.
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: BigBlockMopar] #905837
01/16/11 01:06 PM
01/16/11 01:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes your right for sure, I believe 11" have cooling fins on the outside.
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: BigBlockMopar] #905838
01/16/11 01:07 PM
01/16/11 01:07 PM
Wichita,KS
Wichita,KS
So are you saying he measured he drum instead of the backing plate itself?
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: Blakcharger440] #905839
01/16/11 01:10 PM
01/16/11 01:10 PM
Cincinnati, Ohio
Cincinnati, Ohio
You measure the inside diameter of the drum, I don't think it would be very easy to measure the backing plate? Also measure the width of the drum too.
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: JohnRR] #905840
01/16/11 01:11 PM
01/16/11 01:11 PM
Wichita,KS
Wichita,KS
Hey JohnRR. Are you saying that most all Dodge & Plymouth B bodies if equipped with power disc brakes would have had 10in drums?
Re: What cars & trucks have 11in rear drums from for 8 3/4. [Re: Blakcharger440] #905841
01/16/11 01:18 PM
01/16/11 01:18 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
The Sweptline trucks had a different drum than the big block cars. I have both a '68 Sweptline and a '70 Superbee and they are NOT the same thing. I think the drums might be 11" but they are not the bigger 11" drum with cooling fins that the big block cars got. In addition, the truck drums are becoming much more difficult to find new.
I did a front disc conversion on my Sweptline and one of the things I've been planning on doing is comparing the rear drum setup from a big block car to the Swepty. I converted my Superbee over to all disc (from all drum) and am planning on putting the bigger drum setup on my truck for 1) better stopping power and 2) accessibility of parts.
