Re: What cars & trucks have 11in rear drums from for 8 3/4.
[Re: Exit1965]
#905825
01/16/11 02:47 AM
01/16/11 02:47 AM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
I got mine from a Tradesman Van (b200 maybe?), circa 1974? if I am remembering right. I yanked the stuff off at a junkyard.
That's a real good place to look, the older b vans, my old b van had one.
[Re: Exit1965]
#905831
01/16/11 10:37 AM
01/16/11 10:37 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
65-68 D100 trucks came with 11x2 rear drums. So did the 61-64 trucks but they had the tapered axle.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: ademon]
#905832
01/16/11 10:53 AM
01/16/11 10:53 AM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
My 68 RR has 11" rears, its a power disc brake car
Then someone swapped them on there, the factory installed the wrong rear end assembly or it's not an original disc car because it's supposed to have 10" drums on the rear ....
[Re: JohnRR]
#905833
01/16/11 11:29 AM
01/16/11 11:29 AM
Posts: 15,487 Florida
scratchnfotraction
I used 11x2.5 from a 73 newport 8 3/4 I have used 9 1/4 truck BB&drums also on the 8 3/4 my 72 4x4 truck 8 3/4 has the big 5 on 5.5 wbp with 11x2 brakes i used some 10s from a 8 1/4 on the 8 3/4 also any mid 80s truck with 8 1/4-9 1/4 would be good for that size any of the mid 80s R-body cop cars will have the 11x2.5
[Re: JohnRR]
#905834
01/16/11 12:31 PM
01/16/11 12:31 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
It's a disc car, maybe someone swapped it, stops nice!!
[Re: ademon]
#905835
01/16/11 12:50 PM
01/16/11 12:50 PM
Challenger 1
Cincinnati, Ohio
I agree...
My 71 challenger came with power 4 wheel drum brakes with 11" in the rear.
I installed power disc brakes on the car with the 11" in the rear and it has awesome stopping power now. So does my 74 with 10" drums in the rear.
[Re: BigBlockMopar]
#905837
01/16/11 01:06 PM
01/16/11 01:06 PM
Challenger 1
Cincinnati, Ohio
Be aware that a lot of people don't know how to measure drum-diameter the proper way.
I've received a pair of 10" drums once whichh were advertised as 11" just because the clown-PO just put a tape measure to the drum and measured the OD.
Yes your right for sure, I believe 11" have cooling fins on the outside.
[Re: BigBlockMopar]
#905838
01/16/11 01:07 PM
01/16/11 01:07 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
So are you saying he measured he drum instead of the backing plate itself?
[Re: JohnRR]
#905840
01/16/11 01:11 PM
01/16/11 01:11 PM
Blakcharger440
Wichita,KS
Hey JohnRR. Are you saying that most all Dodge & Plymouth B bodies if equipped with power disc brakes would have had 10in drums?
[Re: Blakcharger440]
#905841
01/16/11 01:18 PM
01/16/11 01:18 PM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
The Sweptline trucks had a different drum than the big block cars. I have both a '68 Sweptline and a '70 Superbee and they are NOT the same thing. I think the drums might be 11" but they are not the bigger 11" drum with cooling fins that the big block cars got. In addition, the truck drums are becoming much more difficult to find new.
I did a front disc conversion on my Sweptline and one of the things I've been planning on doing is comparing the rear drum setup from a big block car to the Swepty. I converted my Superbee over to all disc (from all drum) and am planning on putting the bigger drum setup on my truck for 1) better stopping power and 2) accessibility of parts.
