Hearing protection #904900
01/15/11 02:31 AM
01/15/11 02:31 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
What do you guy's use to protect your hearing? what did you say? It's to many years of no mufflers, grinders, chain saws.
Re: Hearing protection [Re: rowin4] #904901
01/15/11 08:39 AM
01/15/11 08:39 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I have worked in screw machine shops with high noise levels for 24 years and these are my favorites. Some guys leave them stick half way out of their ears, but I shove them in all the way. Don't worry,a pinky fingernail will get them right out.I have tried all different types and they are the most comfortable. Some of the other tapered types have a 1 or 2 decibel better noise reduction rating, but feel like they expand all day and cause pain after a while. The company mandates hearing tests every year and there has been no change in my hearing yet. http://www.coopersafety.com/product/e-a-r-classic-earplugs-1319.aspx
Re: Hearing protection [Re: 67_Satellite] #904902
01/15/11 09:14 AM
01/15/11 09:14 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i got a devorce now my hearing is JUST FINE. all kiddin aside i used that same product when i was in a high noise enviroment,works great(alot better than the cigarette buts we used back in the day)
Re: Hearing protection [Re: rowin4] #904903
01/15/11 10:21 AM
01/15/11 10:21 AM
NC
440Jim Offline
440Jim  Offline
NC
I use foam type ear plugs with my helmet.
Sometimes I run mufflers, and other times running a collector extension with turn out to get the sound past the driver (and methanol fumes out from under the car).
Re: Hearing protection [Re: 67_Satellite] #904904
01/15/11 12:25 PM
01/15/11 12:25 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Same hear. (pun intended)
I like those the best. I buy them in boxes of 200.
People try to make fun of me, I use them so much.
No screw machines at the shop I work at now but,
people don't realize how loud everything actually is,
until it's too late. 8-10 hrs a day for years, takes
it's toll.
Not to mention racing, chain saws, lawn mowers, etc.
Re: Hearing protection [Re: 67_Satellite] #904905
01/15/11 12:58 PM
01/15/11 12:58 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I use the same plugs with power tools building homes, I put em in and leave em in all day, but not all foam plugs are equal, these (link above) are the best IMO. I buy them by the box off EBAY.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Hearing protection [Re: rowin4] #904906
01/15/11 04:34 PM
01/15/11 04:34 PM
HUH, what ear and noise protection, I CAN'T HEAR YOU Looking back now I wish that I had use it back then I see some of the Top Fuel and blwon alcohol crews use the small foam plugs and ear muffs also Same thing on law enforcement shooting ranges
Re: Hearing protection [Re: Cab_Burge] #904907
01/15/11 06:12 PM
01/15/11 06:12 PM
Az
Crizila Offline
Crizila  Offline
Az
Ya, worked in a noisy environment much of my life - before there was OSHA. Paying for it now. I now use those yellow plugs also.
Fastest 300
Re: Hearing protection [Re: Cab_Burge] #904908
01/15/11 07:56 PM
01/15/11 07:56 PM
I wear them with my earmuffs at the range too. The extra "quiet" helps with the concentration factor.
Re: Hearing protection [Re: 67_Satellite] #904909
01/15/11 10:28 PM
01/15/11 10:28 PM
rowin4 Offline OP
rowin4  Offline OP
Looks like the yellow cooper plugs are the popular choice, will have to pick some up, Thats what were used in the factory were I worked for thirty years, Like a dumb #$% I didn't use them. Went for a hearing check, the woman said a hearing aid would be of no use. Well I guess I saved some money on that.
Re: Hearing protection [Re: Crizila] #904910
01/15/11 10:46 PM
01/15/11 10:46 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
In the early 70's during college breaks I worked construction. OSHA was just coming into force and no one on the jobsite wanted to deal with it, so they said let the college kid deal handle it. Hearing protection was one important aspect. I ever since won't even pick up a drill without my hearing protectors on. After almost 40 years in the concert industry as a soundman, etc, I'm lucky to still have a decent set of ears, sadly many others don't.
I believe Cicero said that some of life's most important decisions are made when we are least capable of making them.
I get a kick out of all the TV shows where no hearing protection, welding gloves, dust mask, short sleeves , etc are being worn. I'd face a fine at our shop if we were so careless.
Re: Hearing protection [Re: jcc] #904911
01/16/11 05:38 PM
01/16/11 05:38 PM
Iowa
Hey19 Offline
Hey19  Offline
Iowa
If you click on that link and look at the lower right side the orange Howard Leight are NRR 33 decibel plugs they are slightly better than the older EAR yellows. Also the yellows get stiff with age if you have them around for a while. They are good also. As said before both plugs and muffs are the best for real loud noise situations. As for both plugs or muffs go by the NRR rating on them. The higher the better. 32-33 is about the highest rating for both. There are also the molded reusable style plugs Rubber or silicone some of them are pretty comfortable also. Ear makes them also. Howard Leight makes high attenuation muffs also.
Re: Hearing protection [Re: jcc] #904912
01/16/11 05:44 PM
01/16/11 05:44 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
We used those at my shop for years. We now use the moldex spark plugs that are to the right in the link picture. I like the comfort of the spark plugs better. We have some very high decibles to deal with at work and these do the job. My vote would be either ones, just use something. Beep
Re: Hearing protection [Re: Bigbeep] #904913
01/21/11 04:34 AM
01/21/11 04:34 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
It used to be only real "men" worked in the shop clanging stuff around, throwing wrenches, and hammering on stuff without hearing protection. Now, all those heros can't hear their Grandchildren.
I'll wear my earplugs ANYWHERE, and that includes going to some venue where a wannabe band is on stage trying to make the whole establishment deaf.
A couple of tricks I'll pass on:
1. The yellow earplugs are very effective if you are patient putting them in: Roll them tight to get the right shape for your ear, push them in as far as comfortable, and then hold them with your finger so they expand inside, not pushing their way out.
2. Found this out by accident, but, if you leave the yellow ear plugs in your pant pockets and chuck 'em in the washing machine they come out good as new.
The orange ones that were pointed out, swell up and are useless.
Mo' Farts
Moderated by "tbagger".
Re: Hearing protection [Re: Grizzly] #904914
01/21/11 04:39 PM
01/21/11 04:39 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I just turn my hearing aids off!! That's right...too many years of abuse with no hearing protection.
If you're young, please use some sort of protection...your natural hearing is far better than using hearing aids.
Re: Hearing protection [Re: superwrench] #904915
01/21/11 04:52 PM
01/21/11 04:52 PM
organ
maximum entropy Offline
organ
lol. that's exactly what i do. i've always been deaf, though.
Re: Hearing protection [Re: superwrench] #904916
01/21/11 05:10 PM
01/21/11 05:10 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
My hearing is bad. This past year I have been trying not to make it worst. So I have bought the corded ear plugs for work and racing. Well the first time at the track was totally not good. Right off the bat the burn out was bad because I could not hear the car as good. Then down track I found myselt looking at the shift light and wondering when it was going to light. Then it did and I said oh shoot.( LATE) I found that when I use ear plugs its more like your in your own little world and can not hear what the racer in the other lane is doing. Thats a good thing. I will be using then again but I will make sure that I use them everytime to get use to the differant way the motor and car sounds.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Hearing protection [Re: slippery440] #904917
01/21/11 06:18 PM
01/21/11 06:18 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
It seems that when I am at the local track, I seem to be the only one wearing ear plugs. I use them all the time at work or wherever I need to use them. I keep a db meter with me. I have to record the noise level at work when I do my pre job analysis. Osha and Msha is checking work sites for this now. They will fine you too
Re: Hearing protection [Re: rowin4] #904918
01/21/11 07:14 PM
01/21/11 07:14 PM
eastern time zone
Doug Walker Offline
Doug Walker  Offline
eastern time zone
I work around aircraft and wear foam ear plugs all day long. My preference is Howard Leight or Moldex products. I do not care for the corded ear plugs at all. You can buy these by the box (a few hundred pair) from the nearby Fastenal or Grainger and the pricing is okay.
At the dragraces I am good with the foam earplugs until the nitro cars run. Then if I am anywhere near the starting line I wear both the foam plugs and the acoustic earmuffs. Peltor is the name to go with for earmuffs.
Re: Hearing protection [Re: 67_Satellite] #904919
01/21/11 07:24 PM
01/21/11 07:24 PM
Bellingham, Washington
TERRYTCKL Offline
TERRYTCKL  Offline
How do you get them out if they drop inside?
