Re: Fuel pressure problem (kinda long)
[Re: T-bar]
#904251
01/14/11 10:16 AM
01/14/11 10:16 AM
RapidRobert
Aye mate. You said the 10 micron filter helped. As in it read even lower than 2-4 w the 100 in there? Unless underhood heat as said makes a liquid gauge totally worthless I'd bypass the filter for a 15 minute test (you're not going to pass an exorbitant amt of debris in 15 min) esp since you said going to the 10 micron helped brought the reading up & clean/check the reg and I'm assuming the tank/sock is clean & no pinholes in the hard line/neoprene connector pieces. Holler when you find it
[Re: ProStDodge]
#904254
01/14/11 10:34 PM
01/14/11 10:34 PM
Posts: 1,371 Costa Mesa, CA
chache876
Costa Mesa, CA
Most liquid gauges have a rubber plug which you can use to fill (or empty) the gauge. If the problem is heating of the liquid, you can use the plug to "burb" the gauge and equalize the internal pressure. Its not the temperature of the liquid creating the false reading, it is the expansion of the liquid due to the heat.
what if you drained the liquid? would that eliminate the false readings or are they somehow calibrated with the use of the liquid?
[Re: chache876]
#904255
01/14/11 10:53 PM
01/14/11 10:53 PM
Posts: 163 CT: Corrupticut
Mr71Bee
CT: Corrupticut
Its the pressure caused by the expanding liquid. Had the same problem. I would say either burp and remove some liquid... or install a non-liquid filled gage or move the gage to outside on the bonnet. Don't bring it into the interior! Mr Bee
[Re: chache876]
#904257
01/15/11 06:02 AM
01/15/11 06:02 AM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Yes, you can remove/drain the liquid out and the gauge will work properly.
[Re: T-bar]
#904259
01/15/11 09:33 PM
01/15/11 09:33 PM
Challenger 1
Cincinnati, Ohio
Hello all, I have problem with the fuel pressure staying consistent in my car. It,s a '70 Cuda 440 it has an electric Aeromotive S series pump from Summit it looks like the one to use up to 750hp. It was in the car when i got it so not sure how old it is either but looks fairly new. I have 1/2" line from the pickup to the regulator also aeromotive. I have also put a aeromotive 100 micron filter between pump and tank. Now the problem is when i start it up it has 8.5 psi at the reg take it for a drive and pull up let it idle and check the it and it drops down to anywhere between 2 and 4 psi (gauge is under the bonnet). The previous owner had a 10 micron filter on and i thought that may have been the culprit while it did help it still isn't right. What should i try next.
A return would help alot...You sure you have unostructed flow from the tank? I'd get rid of the 100 micron filter also and try it without for while. I bet that helps alot...
[Re: Challenger 1]
#904260
01/15/11 09:41 PM
01/15/11 09:41 PM
chache876
Costa Mesa, CA
Also, if you already have a sock on the pickup tube, theres no need for a filter between the tank and the pump
[Re: ProStDodge]
#904261
01/15/11 09:46 PM
01/15/11 09:46 PM
chache876
Costa Mesa, CA
Whats the point of it? Acts as a damper?
[Re: T-bar]
#904263
01/15/11 10:42 PM
01/15/11 10:42 PM
Challenger 1
Cincinnati, Ohio
I have a return line on it from the reg back to the pickup. The pickup is an aftermarket 1/2"type with about a 3/16" return line in it also. There isn't a sock on the pickup, i would like to put the brass type strainer on but can't seem to source one here that's 1/2".
Then I would say your experiencing cavation, which means not enough free flow into the pump, I'll bet ya.
Gasoline is very hard to suck, A hi performance pump needs to be supplied with lot's of gasoline so it don't cavatate.
[Re: chache876]
#904264
01/16/11 02:21 AM
01/16/11 02:21 AM
ProStDodge
Yes, the oil is strictly a damper for the needle to reduce vibrations or damper fluctuations to make the gauge easier to read.
