'62 Dart external Trans filter replacement? #904207
01/14/11 01:20 AM
01/14/11 01:20 AM
Champaign, Illinois
mopower76 Offline OP
Champaign, Illinois
What do I do about replacing the external (in line) transmission filter on my '62 Dart wagon (361 4bbl)?
Do these early transmissions have a internal screen? I had another '62 Dart(318)that had a screen and no external filter.
I would like to replace it with another and rather not replace the lines. (seems like good insurance)
Again these early Mopars are fairly new for me and I would appreciate any advice in advance.
Re: '62 Dart external Trans filter replacement? [Re: mopower76] #904208
01/14/11 02:45 AM
01/14/11 02:45 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you need the early stile daycron filter 63-65 for in the pan if you replace the screen .
it will have 2 holes that lay aginst the vb 1 for front pump and a smaller one for the rear pump .
if you use this filter you will not need the one in line , as they are harder to find .
i think i did see the inline advertised someware but i dont remember where now ?
Re: '62 Dart external Trans filter replacement? [Re: calrobb2000] #904209
01/14/11 08:10 AM
01/14/11 08:10 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My kids 62 300 has both.He bought 2 NOS ones a few years ago.They show up on Ebay every once in a while.Rocky
Chrysler Firepower
Re: '62 Dart external Trans filter replacement? [Re: therocks] #904210
01/14/11 06:39 PM
01/14/11 06:39 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Check with Pat Blais at tflitepatty@verizon.net sometimes they have the filter the inline plus the in pan one also.
Re: '62 Dart external Trans filter replacement? [Re: gtx69] #904211
01/14/11 06:48 PM
01/14/11 06:48 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Those line-filters are way OVEkill .. that is why the OEM eliminated them.
Re: '62 Dart external Trans filter replacement? [Re: BeEtLeJuIcE !] #904212
01/14/11 07:19 PM
01/14/11 07:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The OEM eliminated the external filter in '64 when they went from an internal screen with an external filter to an internal filter only. The two were never used together from the factory.
Replacement filters for the pre-'66 must have two inlet holes, one is for the rear pump. Some of the replacement filters don't have the second hole exposed but the internal steel frame still has the hole; push down on the fabric with your fingertip, if you can feel the hole just trim away the fabric to expose the second hole.
Re: '62 Dart external Trans filter replacement? [Re: John_Kunkel] #904213
01/16/11 09:53 PM
01/16/11 09:53 PM
Champaign, Illinois
Champaign, Illinois
Great tips as always! Thank you!
I will be replacing the lines anyway so out with the inline!
Thanks again!!
