Does ARP make a 4" water pump stud #903957
01/13/11 09:22 PM
01/13/11 09:22 PM
Anonymous OP
Anonymous OP
I need 2 water pump studs to hold up my motor to my motor plate and cant seem to find anything bigger than 3-1/4
I think I could get away with 3.5 but 4" would be better. Anyone know where to get a pair.
I found MSC direct but like the ARP quality better.
Re: Does ARP make a 4" water pump stud #903958
01/13/11 09:39 PM
01/13/11 09:39 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Keith, I ran into the same problem and called ARP direct. They will sell you 1 stud if needed. Took a little longer than from Summit or Jegs, but not real bad. I'm thinking it was about a week or so. They were very helpful.
Brian Dunnigan
Re: Does ARP make a 4" water pump stud [Re: '72CudaRacer] #903959
01/13/11 10:48 PM
01/13/11 10:48 PM
Anonymous OP
Anonymous OP
So what size did you go with 3.5 or 4.0".
i'll make the call tomorrow. thanks
Re: Does ARP make a 4" water pump stud #903960
01/13/11 11:52 PM
01/13/11 11:52 PM
Which motor, SB or BB? I bought grade 8 studs from them after calling thier tech people to get the part number for both lengths for the BB Mopar motors using the stock early water pump housings, I did add 3/4 inch to the under head bolt length for the 1/4 inch motor plate and nuts and washers I ended up ordering them from Summit(cheaper than buying them direct from ARP) and had them drop ship them to my shop from ARP
Re: Does ARP make a 4" water pump stud [Re: Cab_Burge] #903961
01/14/11 12:57 AM
01/14/11 12:57 AM
KY
juicedcuda Offline
juicedcuda  Offline
KY
I cut 3/8" all thread and used nuts and washers on them. I haven't had any problems yet.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Does ARP make a 4" water pump stud #903962
01/14/11 01:53 AM
01/14/11 01:53 AM
tn
robnbird Offline
robnbird  Offline
tn
Check with your local parts store with dorman products. They have a complete line of hardware. Plus you can get a grade 8 threaded rod.
Re: Does ARP make a 4" water pump stud #903963
01/14/11 02:21 AM
01/14/11 02:21 AM
AndyF Offline
AndyF  Offline
ARP has them. I use SST studs with a bullet nose. Very high quality parts, better than anything else out there.
Re: Does ARP make a 4" water pump stud [Re: juicedcuda] #903964
01/14/11 07:56 AM
01/14/11 07:56 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Same here.
Re: Does ARP make a 4" water pump stud [Re: AndyF] #903965
01/14/11 09:37 AM
01/14/11 09:37 AM
Anonymous OP
Anonymous OP
What size stud would you recommend for BB with stock Mopar housing and your AFE 3/8" motorplate?
Re: Does ARP make a 4" water pump stud #903966
01/14/11 12:43 PM
01/14/11 12:43 PM
AndyF Offline
AndyF  Offline
You have to measure it to see. A stock water pump housing has different length bolts in some locations.
Re: Does ARP make a 4" water pump stud #903967
01/14/11 11:08 PM
01/14/11 11:08 PM
Mooresburg, Tn
Mooresburg, Tn
Keith, I bought 3.5" studs to use, but I decided to counter sink the nuts into the water pump housing and ordered 3" studs with the reduced wrenching 12 point nuts and flat washers. Mine is a older CSI water pump and a .250" alum engine plate.
Brian
Re: Does ARP make a 4" water pump stud [Re: AndyF] #903968
01/14/11 11:14 PM
01/14/11 11:14 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
How do you use a cam button with that timing cover? I know something goes over the hole but how does it work? Nice looking part.
