Does ARP make a 4" water pump stud
#903957
01/13/11 09:22 PM
01/13/11 09:22 PM
I need 2 water pump studs to hold up my motor to my motor plate and cant seem to find anything bigger than 3-1/4 I think I could get away with 3.5 but 4" would be better. Anyone know where to get a pair. I found MSC direct but like the ARP quality better.
Re: Does ARP make a 4" water pump stud
[Re: '72CudaRacer]
#903959
01/13/11 10:48 PM
01/13/11 10:48 PM
So what size did you go with 3.5 or 4.0". i'll make the call tomorrow. thanks
[Re: Cab_Burge]
#903961
01/14/11 12:57 AM
01/14/11 12:57 AM
Posts: 761 KY
juicedcuda
KY
I cut 3/8" all thread and used nuts and washers on them. I haven't had any problems yet.
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
[Re: AndyF]
#903965
01/14/11 09:37 AM
01/14/11 09:37 AM
ARP has them. I use SST studs with a bullet nose. Very high quality parts, better than anything else out there.
What size stud would you recommend for BB with stock Mopar housing and your AFE 3/8" motorplate?
#903967
01/14/11 11:08 PM
01/14/11 11:08 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Keith, I bought 3.5" studs to use, but I decided to counter sink the nuts into the water pump housing and ordered 3" studs with the reduced wrenching 12 point nuts and flat washers. Mine is a older CSI water pump and a .250" alum engine plate. Brian
[Re: AndyF]
#903968
01/14/11 11:14 PM
01/14/11 11:14 PM
Posts: 1,015 Down South
DaKuda
Down South
How do you use a cam button with that timing cover? I know something goes over the hole but how does it work? Nice looking part.
