slant six 4 barrel #903621
01/13/11 02:16 PM
01/13/11 02:16 PM
N.E. Ohio
SuperD Offline OP
SuperD  Offline OP
N.E. Ohio
Ok I have a slant that needs new goodies on it. What am I going to need to slap on a 4 barrel? I have a holley 750, and am getting the manifold. What else will I need guys? I really need help. Thanks
Re: slant six 4 barrel [Re: SuperD] #903622
01/13/11 03:20 PM
01/13/11 03:20 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
A different engine, or a smaller carb.
750 cfm is WAY to big for even the most radical slants. What are your engine specs? Please tell me you're not bolting a 4bbl on a stock slant...
vm
Re: slant six 4 barrel [Re: vynn3] #903623
01/13/11 03:34 PM
01/13/11 03:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
For the 4bbl to be worth it you better have done some head work, cam, exhaust, etc.
Re: slant six 4 barrel [Re: DaytonaTurbo] #903624
01/13/11 04:31 PM
01/13/11 04:31 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I ran a 1050 Dominator on a 170 slant six in my Imperial. It ran low 12s in the quarter........
Re: slant six 4 barrel [Re: Kern Dog] #903625
01/13/11 04:49 PM
01/13/11 04:49 PM
the 4bbl Holley you want is a 390 CFM one & iirc there's 2 versions or a throttle adapter that you need to pick from but these guys will guide you. www.slantsix.org
Re: slant six 4 barrel [Re: Kern Dog] #903626
01/13/11 05:00 PM
01/13/11 05:00 PM
Downey, IA
Gt383 Offline
Gt383  Offline
Downey, IA
My brother ran a 66 dart, w/ a 225 back in the day with a stone stock engine and we put on an offy and 340 carter avs....made a HUGE difference in performance!!! sounded mean with that throaty carter sound too
If I hafta come in and getchya.......I'm gonna getchya!
Re: slant six 4 barrel [Re: Gt383] #903627
01/13/11 05:08 PM
01/13/11 05:08 PM
N.E. Ohio
SuperD Offline OP
SuperD  Offline OP
N.E. Ohio
Ok so 750, too big. But let's say between 600 and 500 good? Engine is stock. No work done to it other than after market exhaust. I'm planning to bolt on a 4bbl with the offen manifold from summit. I've seen this done with no head work and got good results. Sound better guys?
Re: slant six 4 barrel [Re: SuperD] #903628
01/13/11 05:17 PM
01/13/11 05:17 PM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
As was previously mentioned, a 390 Holley will be plenty of carb. We fabbed a header system (I think the tubes are 1 1/2") that goes into a 3" exhaust, used a Clifford intake and all is good. Stock slant with an od 4spd. Gawd, I love that car. Don't over carb. You will be disappointed.
Re: slant six 4 barrel [Re: wings471] #903629
01/13/11 05:23 PM
01/13/11 05:23 PM
N.E. Ohio
SuperD Offline OP
SuperD  Offline OP
N.E. Ohio
Ok so 390 sounds good. But are there any major parts I need to convert to a 4bbl. The throttle but other than that? To be specific its a 72 duster, and want some more power. Thanks guys
Re: slant six 4 barrel [Re: SuperD] #903630
01/13/11 05:27 PM
01/13/11 05:27 PM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
Clifford has a website as I remember. They have performance cams-head-headers etc. If you really want to go fast, talk to the guys in the induction section here.
Re: slant six 4 barrel [Re: SuperD] #903631
01/13/11 05:32 PM
01/13/11 05:32 PM
Actually unless you are set on a holley prob one of the small '60's AFB's would be fine and for sure be cheaper and tuned right a carter/brock would be better for mileage/driveability at part throttle than a holley but the 390 may be an exception but I do know that it is the std holley used by the /6 boys for 4bbl swaps. I really would checkout the other site
Re: slant six 4 barrel [Re: RapidRobert] #903632
01/13/11 05:50 PM
01/13/11 05:50 PM
P
Paul_Fancsali Offline
P
I have seen and used 600 holley's on slant 6 engines run a heavy spring on sec and it will work just fine same goes with 750 way too much carb and pig rich but you can use it with a heavy spring brown or black. Just I don't want to bhe behind you in traffic unless your real good at idle circuit mod's
Re: slant six 4 barrel [Re: RapidRobert] #903633
01/13/11 05:58 PM
01/13/11 05:58 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
You need to learn some basic engine hotrodding principles.
You could actually get a cheap Carter like another poster was saying. Have it rebuilt.
The Offy is a decent intake. I am curious about the Aussiespeed Hurricane. It looks like a better design.
Clifford is really bad about customer service.
Come on over to the slant site!
We'll be there!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: slant six 4 barrel [Re: wings471] #903634
01/13/11 07:33 PM
01/13/11 07:33 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
Under no circumstances should you send any money to Clifford without LOTS of research at slantsix.org. A rare few have had no problems, but overall Clifford has a TERRIBLE reputation for taking people's money and not providing product (or making them wait many months).
I would recommend milling the cylinder head to increase compression and starting with a super six conversion. That made a HUGE difference on my slant. Slants don't generally respond that well to simple bolt-ons (unless they have a good foundation).
vm
Re: slant six 4 barrel [Re: Rug_Trucker] #903635
01/13/11 07:35 PM
01/13/11 07:35 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
IF the rest of the motor is going to stay unmolested, save yourself a headache and watch for a used Offy intake and get a decent 390 vacuum secondary Holley. IIRC the list number you want is 8007.
An Offy will give better low end performance on the street than a Clifford.
Is the car stick or auto? For a stick you can just get a universal bracket for the throttle cable, for an auto you'll have to fab up kick-down linkage too.
You will also want to do some exhaust work, either split manifolds or a pair of headers. You'll be glad you did.
Re: slant six 4 barrel [Re: slantzilla] #903636
01/13/11 08:02 PM
01/13/11 08:02 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
When I first started with my stock 225 I bought a 2bbl Cast Iron intake and mounted a 2bbl 500 Holley to it...Too much
I then mounted a modified 4bbl 390 Holley with a 4bbl Aluminum Offy Manifold, placed a secondary metering block on the rear. Ran okay...not great...but she had some extra power.
I then added the Direct Connection Slant 6 into 1 header...Heavy denting on the #4 or #5 tube to clear the power steering unit....Ran like that for 2 yrs...
I went to the boneyard and found another head in decent condition, sent it out, had a mild cleanup in the bowls performed, 5 angle valve job, replaced all the seals and the valves, opened up the intake and exhaust ports. Milled it .100 to bump my compression up. My main purpose was to remove the 3/8" stems and replace them with 5/16" Fords but the guy at the shop said its a waste of money and leaned me towards the 5 angle job. I put $1500 into that head
Rebuilt the entire motor, replaced the pistons, matched a working set of rockers (they tend to crack on the surface). Got a .436 lift Isky cam. Swapped over to MSD at this time because the Orange ECU was being replaced every 6 months for some reason. I bought a set of Tri-Y headers from Clifford. I heard about the bad customer service so I ordered the plain coated ones, drove to pick them up (3 hours road trip) I sent them in to another place and had them coated for 100 bucks.
Slipped that head on to the new motor, bolted on a rebuilt 904 w/ shift kit. Installed the Clifford Tri-Y headers, the aluminum 4bbl Offy with a 500cfm Edelbrock....That setup was immaculate...I drove it everywhere...I think there was a time span of about 7 months that I didn't even lift the hood once.
Check out the link in my signature and you can read all about the mighty slant, where she came from and where she went...Pics are there too
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: slant six 4 barrel [Re: SuperD] #903637
01/14/11 06:51 AM
01/14/11 06:51 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I'd install an aftermarket kickdown too...your stock linkage wont work with headers. I ran a Lokar on that car (its was Pre-Bouchillon kits) but if I had to...I would go with BPE again.
My exhaust was 2 1/4" to the mufflers on each side. I ran Delta 50s. I heard SpinTechs on a slant make it go wilder with lope but I can't attest to it personally
