Re: big block heads 906 vs 346
[Re: Kern Dog]
#903216
01/13/11 03:32 AM
01/13/11 03:32 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
IIRC the 346 has hardened seats, although the 906 seats are now known to survive just fine on unleaded for short term use, just cruising around. Performance wise? you will never know the diff
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#903217
01/13/11 03:36 AM
01/13/11 03:36 AM
R70RUNNER
Riverside, Ca
Everything you ever wanted to know about BBM factory iron heads Edit for correct article
[Re: AB&E]
#903219
01/13/11 05:37 PM
01/13/11 05:37 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
so performance wise they are just as good ??? will they effect compression they are on my 1970 440hp motor that I am getting ready to 6pk
Depends on if they are cut or not , as cast they should be the same cc , 90-92 . As far as the induction hardening , it's deeper and wider than you'd think , had a set of 452's that got 1.81 exh and the material was hard out to that valve size , didn't need an insert .
