Page 3 of 4 1 2 3 4
Re: Cowl hoods [Re: poisondart2] #902696
01/19/11 01:48 PM
01/19/11 01:48 PM
Edmonton alberta Canada
mr. 63plymouth Offline
The loss of performance is that cowl hoods are kind of a CHEV thing!!Just my LOL 9.52 in street clothes with two pins and two hinges @ 143MPH
Re: Cowl hoods [Re: mr. 63plymouth] #902697
01/19/11 06:18 PM
01/19/11 06:18 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Mine does not work at all..it a very nice hood 5inch glasstek...I have tried everything.it will ruin a set of plugs..lol
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Cowl hoods [Re: FASTFISH420] #902698
01/19/11 07:07 PM
01/19/11 07:07 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
you mean my car can go faster????
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Cowl hoods [Re: bigtimeauto] #902699
01/19/11 11:00 PM
01/19/11 11:00 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Yes it can.
Re: Cowl hoods [Re: bigtimeauto] #902700
01/19/11 11:06 PM
01/19/11 11:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
man I cant find the pic of how the front of my dart was to hold the front part of hood down
Mopar Performance
Re: Cowl hoods [Re: moparniac] #902701
01/19/11 11:40 PM
01/19/11 11:40 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
i like the way cowl hoods look on cudas and darts
Re: Cowl hoods [Re: one bad fish] #902702
01/20/11 02:21 AM
01/20/11 02:21 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have always thought my car would run faster with a cowl hood, that big scoop shovel has to slow a car down, it's like driving with your door wide open. If you have a opening as big as a cowl, air will find it's way to the carb.
Re: Cowl hoods [Re: rowin4] #902703
01/20/11 03:07 AM
01/20/11 03:07 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I have tried acouple different hood scoops also..a hemi and six pack and they dont work either..I love the cowl..if I redo the hood it will be a 6 inch that goes to the windshield..I need to put a good aero scoop on it,but hate to deface the car with it..I run such a big cfm carb..it needs all the airflow it can get..
Been running the carb out the scoop hole and running a big aircleaner on it..just for testing mode purposes..
Re: Cowl hoods [Re: FASTFISH420] #902704
01/20/11 06:08 AM
01/20/11 06:08 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Ever try anything like the PS trucks had? Cowl hoods with a front facing airpan. Aerodynamic benefit of the cowl and just redirect air that would hit the front of vehicle anyway.
I like the looks of the cowl, however I'm just not subscribing to the "air off the windshield" lore.
My 6" cowl goes back to an inch or so of the windhield and has a 2pc forward facing pan setup. Still sorting out electrical issues and have not had it over 140 yet, which is where I expect it to start making a difference.
Good Luck
Re: Cowl hoods [Re: TheBlackCar] #902705
01/20/11 08:42 AM
01/20/11 08:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Good Luck
I've wanted to test my scoop VS a cowl in cars that
run the same speed... just putting a inches of water
gauge with a pick up tube in the cowl and scoop...
at least I know that if the front facing scoop is
high enough to be in the air flow it applies pressure
at speed where the six pack type arent high enough
and may actually hurt performance
Re: Cowl hoods [Re: rowin4] #902706
01/20/11 09:26 AM
01/20/11 09:26 AM
Highland beach Fl
P
poisondart2 Offline OP
P
Highland beach Fl
It has to catch alot of air like putting a chute on the front of the car and pushing against it.Looks like most on here that have a cowl are 140 or better with no complaints of a loss.
Re: Cowl hoods [Re: poisondart2] #902707
01/20/11 09:30 AM
01/20/11 09:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It may be a like a chute BUT if its in the air flow
its pressurizing the carb(cheap supercharger)
Re: Cowl hoods [Re: MR_P_BODY] #902708
01/20/11 09:37 AM
01/20/11 09:37 AM
Highland beach Fl
P
P
Highland beach Fl
Yeah but at what point does the drag on the car outweigh the forced air ? and would it not be better to be more aerodynamic and force the air another way like with a tube to the carb like the Fords use?
Re: Cowl hoods [Re: poisondart2] #902709
01/20/11 09:48 AM
01/20/11 09:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Very true... I'm sure there is a trade off... I am
planning on using a cowl on my drag week car BUT using
a pair of front mounted tubes to supply the air to
a sealed air pan... hopefully this will give me the
best of both worlds
Re: Cowl hoods [Re: MR_P_BODY] #902710
01/20/11 09:49 AM
01/20/11 09:49 AM
Highland beach Fl
P
P
Highland beach Fl
So we think alike
Re: Cowl hoods [Re: poisondart2] #902711
01/20/11 12:40 PM
01/20/11 12:40 PM
rowin4 Offline
rowin4  Offline
I'd like to see what a Hemi hood scoop would look like on a car that would be in the air flow, It would have to be over a foot tall.
Re: Cowl hoods [Re: rowin4] #902712
01/20/11 02:32 PM
01/20/11 02:32 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Re: Cowl hoods [Re: FASTFISH420] #902713
01/21/11 08:14 PM
01/21/11 08:14 PM
Suwanee, Georgia
srracing8 Offline
srracing8  Offline
Suwanee, Georgia
I've always wondered how some of you see around the tall scoops sitting at the tree? I have a 6" cowl hood and the way I sit in my car any lower I would have to put a wedge under the seat to see the tree.
I've watched some of the ProStock and ProMod racers when in the left lane stretching their necks to see the lights.
Just some thoughts.
PoisonDart post some photos with the wheels up. You are loosing et with all the air under the car. LOL
1/8@5.83/120mph 1/4@9.28/143mph
Re: Cowl hoods [Re: srracing8] #902714
01/21/11 08:22 PM
01/21/11 08:22 PM
rowin4 Offline
rowin4  Offline
I'll give up a little , It sure does look more exciting to the spectators.
Re: Cowl hoods [Re: poisondart2] #902715
01/21/11 08:29 PM
01/21/11 08:29 PM
Fredericksburg,Virginia
1 Bad Duster Offline
Here my 4" cowl hood..
1973 Pro Street Duster
Page 3 of 4 1 2 3 4
