headliner repair #902630
01/12/11 10:16 AM
01/12/11 10:16 AM
btomasko Offline OP
btomasko  Offline OP
How would you repair a small hole about a 1/4 inch in a roadrunners headliner, rest of liner in good condition. thanks need ideas
Re: headliner repair [Re: btomasko] #902631
01/12/11 10:20 AM
01/12/11 10:20 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
You can look at auto parts store to see if they have that iron on vinyl fix stuff. Depending on where the hole it, you may never notice the repair.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: headliner repair [Re: 70Coronet500Vert] #902632
01/13/11 12:09 AM
01/13/11 12:09 AM
btomasko Offline OP
btomasko  Offline OP
BTT
Re: headliner repair [Re: btomasko] #902633
01/13/11 12:23 AM
01/13/11 12:23 AM
rhode island
bomber1965 Offline
bomber1965  Offline
rhode island
....add another dome light....
Re: headliner repair [Re: bomber1965] #902634
01/13/11 09:23 AM
01/13/11 09:23 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Where is the hole?
Another idea would be to remove a trim strip and cut off a small piece of material from a hidden area.
First glue a slightly larger piece behind the hole by working it through the hole. Let that dry well first,
then fit a patch the exact size of the hole & glue it in place.
If needed, some small dabs of vinyl repair material around the edge should make it nearly in-detectable...
Rick
Re: headliner repair [Re: RestoRick] #902635
01/13/11 10:21 AM
01/13/11 10:21 AM
GA
Boosted Offline
Boosted  Offline
GA
How old is the headliner now? If it is pretty old but liiks ok on the outside I would bet it is not so good on the inside...
I would say replace it... Do it once and do it nice... It will then last many many years....
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
