Big Block Timing Cover #902178
01/11/11 06:18 PM
01/11/11 06:18 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Does anyone know of a Big Block 2 piece timing cover so you can adjust cam timing on the dyno?
Max Weg
Re: Big Block Timing Cover [Re: Max Weg] #902179
01/11/11 06:33 PM
01/11/11 06:33 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
I think Andy F makes some.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Big Block Timing Cover [Re: fed] #902180
01/11/11 06:40 PM
01/11/11 06:40 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Do you have any contact info?
Max Weg
Re: Big Block Timing Cover [Re: Max Weg] #902181
01/11/11 06:50 PM
01/11/11 06:50 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I think the one AndyF makes is the same part that Mancini and Hughes sell. Not cheap, but I saw one in person and all over it.
Re: Big Block Timing Cover [Re: Max Weg] #902182
01/11/11 06:51 PM
01/11/11 06:51 PM
AndyF Offline
AndyF  Offline
Mancini Racing and Hughes Engines have the covers in stock. You can adjust the timing as long as you use an adjustable timing set like a Cloyes Hex-a-just. If the timing chain has to come off to adjust the cam timing then you have to pull the cover.
Re: Big Block Timing Cover [Re: Max Weg] #902183
01/11/11 06:53 PM
01/11/11 06:53 PM
AndyF Offline
AndyF  Offline
In Canada you can buy them from Tim at FHO.
Re: Big Block Timing Cover [Re: AndyF] #902184
01/11/11 07:01 PM
01/11/11 07:01 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Hi Andy,
for the reply, I will check it out tomorrow.
Max Weg
