Duster rear tires #902148
01/11/11 04:57 PM
01/11/11 04:57 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...a friend wants to put a 29" tire on his big block '72 Duster.
i told him a 275 60 15 at 28" was as tall as i thought you could go, without a 1" spacer ahead of the front spring mount...anyone try this?
what backspace is necessary for 275 60 15?
.tx guys
Re: Duster rear tires [Re: can.al] #902149
01/11/11 05:06 PM
01/11/11 05:06 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
4.5" backspace on 15X8 rims with my 275/60/15's
Re: Duster rear tires [Re: dustergirl340] #902150
01/11/11 05:28 PM
01/11/11 05:28 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i would think with that tire you would need to get the body up.ss springs,air shocks ect
Re: Duster rear tires [Re: dustergirl340] #902151
01/11/11 05:34 PM
01/11/11 05:34 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..he is going w/15 x 7 rims but the backspace should be the same.
he does have ss springs
how much space between springs and tire?
Re: Duster rear tires [Re: can.al] #902152
01/11/11 05:39 PM
01/11/11 05:39 PM
Outside
thedriver Offline
thedriver  Offline
Outside
255/70/15 is 29" tall. close to same width as a 255/60/15.
i would think it would fit nicely.
1973 challenger
Dana. 4 speed. Low deck.
Re: Duster rear tires [Re: thedriver] #902153
01/11/11 05:46 PM
01/11/11 05:46 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
gotta watch height so as not to rub to front edge of the wheel well, thats the tighest point, I have 255x60 R15 because I play it safe..well, Except I have 2 1/2" backspaced 15x8's..lol 2" over springs are the key there..
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Duster rear tires [Re: thedriver] #902154
01/11/11 05:46 PM
01/11/11 05:46 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
The only other area he needs to look at is the front leading
edge of the rear wheel openings to make sure it clears other
wise he will need to trim that leading edge.
Phil Saran Parker, Colorado
Re: Duster rear tires [Re: thedriver] #902155
01/11/11 05:47 PM
01/11/11 05:47 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..255 60 15 is 27"
Re: Duster rear tires [Re: can.al] #902156
01/11/11 07:36 PM
01/11/11 07:36 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
a drag radial at 275/60-15 is about the biggest meat you'll stuff under there w/o other mods.
Re: Duster rear tires [Re: Kudakidd] #902157
01/11/11 07:43 PM
01/11/11 07:43 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
with 02&03 SS springs you can use a 295/50/15 on a 15x10 rim with 4.5 back space.
Re: Duster rear tires [Re: 9 Sec Phill] #902158
01/11/11 08:48 PM
01/11/11 08:48 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
These are 29"
Re: Duster rear tires [Re: bp27] #902159
01/12/11 02:58 AM
01/12/11 02:58 AM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
These are 325/50x15 BFG Drag Radials -- I'm pretty sure they are 29" tall. No way they will fit my Demon without moving the axle back about an inch.
