firecore distributor and EZ heads 440 #902143
01/11/11 04:47 PM
01/11/11 04:47 PM
chicago il usa
K
komninon Offline OP
komninon  Offline OP
K
chicago il usa
does the firecore distributor clears the EZ HEADS or needs grinding?
Re: firecore distributor and EZ heads 440 [Re: komninon] #902144
01/11/11 05:11 PM
01/11/11 05:11 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
The mechanical dist clears but if you want to run the RTR you will need to do some machining and I do not know how much you can safely remove before going into the water jacket. Check out the posts under new products under FIRECORE DISTRIBUTORS ARE IN
Re: firecore distributor and EZ heads 440 [Re: Hemi_Ram] #902145
01/11/11 05:17 PM
01/11/11 05:17 PM
chicago il usa
K
komninon Offline OP
komninon  Offline OP
K
chicago il usa
i am going to use the mechanical.
thank you
