Home-made sup't dolly for big block engine and trans
#901922
01/11/11 09:08 AM
01/11/11 09:08 AM
Posts: 395 Knoxville, TN, USA
mantonas
Knoxville, TN, USA
I will be storing a big block engine and transmission in my garage for a while, and I want to build a support dolly on wheels for it. I don't have the engine and trans yet to take measurements, and I would like to have the dolly built before I get it. I don't need it to bolt in, just to not wobble and fall off the dolly while I roll it around. Other than the wheels, I am hoping to build it with scrap lumber and some perforated steel angles that I have laying around in my garage.
I'm thinking about something that has three support points to correspond to the transmission cross member and the motor mounts. Does anyone have the dimensions of these three points? I need the following dimensions:
1. The horizontal spacing of the motor mounts. 2. The distance between the motor mounts and the transmission cross member. 3. The vertical offset between the transmission cross member and the motor mounts.
These dimensions can be approximate, and I can shim it up, but I would just like to put something strong below these points, as this is where the load will be taken.
Alternatively, I am open to suggestions to doing something else. I thought about going to Harbor Freight and buying three of those dollies that accept a tire, that you use to be able to roll your entire car around in the garage. One each under where the motor mounts attach and one under the transmission cross member support point. I would like to spend as little as possible, so since I know I would end up buying four of these to use under a car in the future, this is not as desirable as my home-built dolly.
Any other ideas?
69 Chrysler 300 Convertible
77 Chrysler New Yorker Brougham 2-dr
03 Jeep Grand Cherokee Limited
Re: Home-made sup't dolly for big block engine and trans
[Re: Commando1]
#901924
01/11/11 12:58 PM
01/11/11 12:58 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
you're making a ton of unescessary work for yourself that way
??? How do you figure that ???
Anyhow, many years ago I built something like this out of 2x4's and plywood. I built a "box" that the oil pan sat in and then attached 24" 2x4's across the front and back to mount casters and stabilize the unit. It didn't need to be any bigger than the engine since the engine weighs so much more than everything else.
[Re: Stanton]
#901925
01/11/11 02:14 PM
01/11/11 02:14 PM
Posts: 182 NW of Indy
Thackdaddy
NW of Indy
I use a furniture dolly, the oil pan sits on the front 2x6, the trans pan the rear one.
'71 Duster
[Re: Devil]
#901929
01/11/11 06:01 PM
01/11/11 06:01 PM
Posts: 396 California, USA
Phil Saran
California, USA
I second or third the HF furniture dolly's. I've got two engines sitting on thar type of dolly and it works fine.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#901930
01/12/11 02:33 AM
01/12/11 02:33 AM
mantonas
Knoxville, TN, USA
The Harbor Freight furniture dolly sounds perfect. They are on sale for $10 each - I don't think I could buy four wheels at Home Depot that cheap! I can use some of my scrap lumber to shim the engine and trans up as required.
Thanks for giving me the benefit of all of your experience.
