Lokar Kickdown Cable Adjustment #901896
01/11/11 07:57 AM
01/11/11 07:57 AM
Surface of the Sun, AZ
Hotwheelsjr Offline OP
Ok -- I've adjusted my son's 400/727 Lokar kickdown by pulling the slack out of the cable at WOT so he has full pressure at WOT. The tranny kicks down when the pedal is smashed, but the problem we have is it doesn't like to shift from 2nd to 3rd until about 3500rpm. 1st to 2nd seems ok around 1500-2000rpm. Cruising through the neighborhood at 25-30mph the tranny will not upshift to 3rd. Too much pressure at low throttle? What can we do to adjust the 2nd to 3rd shift point?
Re: Lokar Kickdown Cable Adjustment [Re: Hotwheelsjr] #901897
01/11/11 08:32 AM
01/11/11 08:32 AM
Netherlands
72Challenger Offline
Netherlands
Have that cable in 'your' duster too with the 340. Have you tried giving the cable a tiny bit of slack at WOT? Could be it...
Re: Lokar Kickdown Cable Adjustment [Re: 72Challenger] #901898
01/11/11 09:13 AM
01/11/11 09:13 AM
DUDE! How the heck are ya? How's the Duster doing these days? Any new pics or videos you can share with me? Damn I miss that car...
I have a Lokar setup in my Demon too, but I never let the tranny auto-shift, so I've never paid much attention to it in there. My son's RR is a daily driver and shifting at 3500 all the time is becoming a pain. I'll try and take some pressure away from it to see if the shift points drop. Anyone else?
Hans -- send me some pics and/or vids of the ol' Duster when you get a chance. PM me.
THANKS!
Re: Lokar Kickdown Cable Adjustment [Re: Hotwheelsjr] #901899
01/11/11 09:19 AM
01/11/11 09:19 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I agree - and give it about 1/8" of slack at WOT
Re: Lokar Kickdown Cable Adjustment [Re: Hotwheelsjr] #901900
01/11/11 09:48 AM
01/11/11 09:48 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
To be honest with you, I'm no fan of the Lokar Cable. I had the same probs as you and it took a lot of trial and error to get it right. If you're not right you can cause probs. with your tranny. I'm switching to Bouchillon when I get my auto car back together. I had a talk with them last week and I think that's the way I'm going. They at least know what a Mopar is, Lokar is cool if your a street rodder or GM.
Re: Lokar Kickdown Cable Adjustment [Re: DANA60] #901901
01/11/11 11:02 AM
01/11/11 11:02 AM
Thanks all -- and although I agree the Bouchillon one is superior to the Lokar, he already has the Lokar and can't shell out $130+ for the Bouchillon right now. I've thought about it numerous times, but money winds up getting spent on needs rather than wants.
Re: Lokar Kickdown Cable Adjustment [Re: Hotwheelsjr] #901902
01/11/11 02:23 PM
01/11/11 02:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
problem with the lokar , from reading posts , is it's a generic setup and needs to be adjusted to work properly in a mopar application , the ratio of the throttle movement to the arm on the trans is not correct , takes trial and error drilling holes and moving the cable pin , which way and how much ????
Re: Lokar Kickdown Cable Adjustment [Re: JohnRR] #901903
01/11/11 02:56 PM
01/11/11 02:56 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
just give it 1/8" slack and drive the damn thing first...
Re: Lokar Kickdown Cable Adjustment [Re: DJVCuda] #901904
01/11/11 04:12 PM
01/11/11 04:12 PM
Winnipeg, MB, Canada
71Plym Offline
71Plym  Offline
I agree with DJVCuda. I had the same shifting issue. Adjusted in some slack and issue was solved.
Re: Lokar Kickdown Cable Adjustment [Re: 71Plym] #901905
01/12/11 02:16 AM
01/12/11 02:16 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Adjusting for slack will only solve your problem at partial throttle. You will ALSO lose your high rpm upshift.
To have both an earlier upshift at partial throttle AND a max rpm shift at WOT.
You need to shorten the throttle lever on the transmission. Basically you drill another hole inboard on the throttle lever.
A shorter lever will give you more action or a bigger sweep for the same amount of cable travel.
Re: Lokar Kickdown Cable Adjustment [Re: Magnum] #901906
01/12/11 05:35 AM
01/12/11 05:35 AM
Netherlands
Netherlands
Tryed the re-adjusting already
You've got a PM
Re: Lokar Kickdown Cable Adjustment [Re: 72Challenger] #901907
01/12/11 09:19 AM
01/12/11 09:19 AM
You've got a PM
Yes -- I backed it off some and it's better but not totally fixed. Trial and error...or $140 for the Bouchillon.
Re: Lokar Kickdown Cable Adjustment [Re: Hotwheelsjr] #901908
01/12/11 01:33 PM
01/12/11 01:33 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
You've got a PM
Have it on my 383. Backed it off a bit and it shifts exactly where I like it. Granny-driving it will go in to 3rd at a low RPM. Shifts on it's own at WOT around 4900 RPM's. I manually shift it a lot anyway. At WOT I usually manually shift at 5800 RPM's. Tires spin some, real firm shift, so it has plenty of pressure. Been driving it this way for years. Still shifts great.
Changed tranny fluid recently. Fluid looked really good even for being in there a few years.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Lokar Kickdown Cable Adjustment [Re: Junky] #901909
01/12/11 03:19 PM
01/12/11 03:19 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
have been using lokar cables for years and have never had a problem. i always set them up to short shift a bit when on the floor boards because i figure on the street where am i going to really wind it up to 6000 rpm over and over. if i want to really wind it up i'll shift myself. on the street i like it to shift at about 4500 rpm on the floor boards..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Lokar Kickdown Cable Adjustment [Re: abodyjoe] #901910
01/12/11 03:30 PM
01/12/11 03:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have noticed that if you drill a new attaching hole in the kickdown lever about a 1/2-3/4" inboard of the original hole it helps the carb to lever ratio. That makes it work better and easier to get adjusted where you want it
Re: Lokar Kickdown Cable Adjustment [Re: stumpy] #901911
01/12/11 04:49 PM
01/12/11 04:49 PM
Thanks all.
Re: Lokar Kickdown Cable Adjustment [Re: Hotwheelsjr] #901912
01/12/11 06:48 PM
01/12/11 06:48 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I ended up drilling a hole about half way in on the the trans lever and it did work better. I used a very old lever off a older trans that had more meat on it.
Re: Lokar Kickdown Cable Adjustment [Re: DANA60] #901913
01/12/11 09:57 PM
01/12/11 09:57 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
if you move the pivit point closer to the center it will move slower so it will not apply as quick on light throttle
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
