Block filler...
#901794
01/10/11 11:06 PM
01/10/11 11:06 PM
Posts: 311 Colorado Springs, Colorado
Dartthunder340
How many of you have your block filled? Could you please explain the pros and cons? Would be for a drag only car. Thanks.
Better get inside Ma. Looks like a storm's comin'.
Re: Block filler...
[Re: Dartthunder340]
#901796
01/11/11 11:35 AM
01/11/11 11:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've got a couple of blocks filled(half filled) and it holds the walls in place better which should give better ring sealing BUT being that the water isnt traveling in the lower part of the block the oil tends to pull the heat off of the block so the oil gets hotter than with the water.... so you need a oil coller
Re: Block filler...
#901797
01/11/11 02:06 PM
01/11/11 02:06 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
I don't recommend using any cement(sidewalk stuff) based fillers, it expands when curing and then shrinks I have used it in several blocks and found out that the block ends up having two different temperature zone by using a hand held infrared temp gun on a motor being dyno tested, it was (after several pulls where made to warm up the oil, seat the rings and so on) a different temp at and below the fill than above the fill We had the thermostat set at 120 F on the water tower and the water in the heads and the top of the block above the fill was 120F, the block at and below the filler was 180F That makes me think that the cylinders are two different sizes above and below the fill The rings can accomadate(SP?) some differences, evidently, but I prefer straight cylinder walls I have had to replace a freeze plug(soft plug) in a filled block and the filler had pulled away from the side of the block some, not much but some It is your choice Lots of racer and machinest like filler and some don't
Re: Block filler...
[Re: Cab_Burge]
#901799
01/12/11 12:42 AM
01/12/11 12:42 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Cab, with our Fontana block without filler vacuum went positive about about 8 grand. With it filled it held at least 5# vacuum through the lights.
Re: Block filler...
[Re: BobR]
#901800
01/12/11 09:58 AM
01/12/11 09:58 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I have seen results as such. I believe in it in the right applications. You must do proper prep, and use proper materials, and it is absolutley beneficial. Done wrong, it will make a mess,and make ring seal worse.There are other materials, other than the commercially available brands, that work better.
It also serves other functions than just cylinder wall stiffening.
RIP Monte Smith
Re: Block filler...
[Re: MR_P_BODY]
#901802
01/12/11 10:32 AM
01/12/11 10:32 AM
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
Re: Block filler...
[Re: MR_P_BODY]
#901804
01/12/11 06:20 PM
01/12/11 06:20 PM
Posts: 976 ontario canada
mac56
ontario canada
Todd what materials are you referring to that is even better?
Me too please. I have mine filled to the top.
Re: Block filler...
[Re: mac56]
#901805
01/12/11 07:16 PM
01/12/11 07:16 PM
Posts: 5,080 organ
maximum entropy
organ
i'm a buhleevuh. especially in rb engines. the low deck i don't think is nearly as critical. i've only filled one block so far (tall deck), and it has made it through it's first season without incident. i'm doing one now that will be a partial fill. time will tell. i use hard blok. no problems yet. sometimes you have to follow your gut and find out what works for you.
