procharged smallblock
#901640
01/10/11 10:24 PM
01/10/11 10:24 PM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
starting to gather ideas on a sb build, where should i begin to look for ideas,on internals of the block, any help with heads would help too
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: procharged smallblock
[Re: Cudahlr]
#901642
01/11/11 01:56 AM
01/11/11 01:56 AM
Posts: 693 Coronado, CA
go-fish
Coronado, CA
I have a pretty nice engine I put together. It wasn't cheap.
I have a 1971 360 block (up to 1975, I think, are stronger blocks due to high nickel content)
Hughes Engines girdle Roller lifters/rockers sourced from Hughes K1 forged 4" crank/rods Diamond forged pistons custom built for me (I have the serial # so they can be reproduced w/ their program) Hughes cam (alot like a 5.9 Dak R/T cam but on 114LSA) Eddy Stage II heads from Hughes Eddy Super Victor Jr. intake. Melling HV pump Eddy high flow water pump MSD Pro Billet dist. MSD 8mm wires Cometic Gaskets
Good for 650 hp and 589 lb/ft torque at Southland Performance in Gray, LA. It looks like they are Southland Speed now.
I can look up the dyno sheet somewhere I'm sure. It could do even better but it's right where I want it. Definitely could reach the limits of the stock block really easily. I wouldn't do this with a non-"high nickel" block. I would love to do the same thing but a 416" with a 340 resto block.
Oh, D1-SC kit was from the Supercharger Store.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
[Re: Stroker Scamp]
#901643
01/11/11 03:14 AM
01/11/11 03:14 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
My procharged 340 has been together since 1998 and runs great still with a ton of miles on it. In terms of what mods are needed you need to tell us more about your goals. If your going to try for a mild 600hp street motor its really easy, but if you have aspirations of a 1000hp terror a ton more is needed.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: Hitman340]
#901646
01/13/11 04:46 PM
01/13/11 04:46 PM
Posts: 489 mid Ga.
W5Dart378
mid Ga.
I'm currently working on brackets to mount a reverse rotation F1r on an X block. If anyone is intrested let me know.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s
69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
[Re: W5Dart378]
#901647
01/13/11 08:37 PM
01/13/11 08:37 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Steve Morris does'nt work @ Steve Morris Racing Engines anymore... I know it's odd his name is on business he is no longer affiliated with but... just FYI you won't get ahold of him there. Last I knew he was @ New Era Race Craft, but I think I may have read he bounced around again after that but not sure. But that being said, there are lot's of people/places that can build a good ProCharger motor/give you good advice. Getting camshaft right is really biggest hurdle, the rest is pretty straight forward. As far as the actual engine goes....It's just a blower motor... Mounting/packaging the Procharger is much more difficult than building good motor for it. & if you're gonna do blow through carb, I'd head over to http://www.theturboforums.com/smf/index.php& read up in the blow through section.
[Re: RyanJ]
#901650
01/14/11 10:54 AM
01/14/11 10:54 AM
Posts: 193 Houston, TX
rick55
Houston, TX
Steve Morris Race Engines no longer goes by that, they are now SMRE and no affiliation to Steve Morris. Steve's shop is at www.stevemorrisengines.com. He still has some affiliation with New Era Racecraft but because of space limitations at NER has opened his own shop. My son works for Steve.
[Re: madmoparmike]
#901653
01/18/11 10:37 PM
01/18/11 10:37 PM
Posts: 814 in front of the computer
80arrow
I'm currently putting a F1R on a small block mopar. It was a kit that places the procharger on the passenger side. I believe that you can get brackets from Steve Morris for a small block. Another good site for info is Yellow Bullet. My kit was from SD Concept Engineering.
[Re: Cudahlr]
#901656
01/19/11 12:12 AM
01/19/11 12:12 AM
80arrow
I'm currently putting a F1R on a small block mopar. It was a kit that places the procharger on the passenger side. My kit was from SD Concept Engineering.
More info please!
Im doing the same thing in a 68 barracuda, and using a Sd bracket as well
Let me know what you want, I'll tell you whatever I know. It might not be right but I'm new to this also.
[Re: 80arrow]
#901657
01/19/11 04:15 AM
01/19/11 04:15 AM
Stroker Scamp
pacific northwest
do they give you specs on how much HP it takes to drive the procharger
