Re: Valve Train Deflection
[Re: sg66mopar]
#901532
01/10/11 09:20 PM
01/10/11 09:20 PM
Posts: 4,206 New York
polyspheric
New York
There are only 2 places that have a lot of compliance, and only 1 that's easy to fix. How big are your pushrods?
Boffin Emeritus
[Re: sg66mopar]
#901537
01/10/11 11:19 PM
01/10/11 11:19 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this a single shaft system... you most likely have a few different places flexing.... the push rod, the rockers and the shafts EDIT Forgot to add the cam itself flexing but your not running big spring pressure... whats the cam diameter
[Re: MR_P_BODY]
#901538
01/11/11 12:10 AM
01/11/11 12:10 AM
Posts: 1,200 UK
602heavy
UK
Are both heads on & valve train lashed?
[Re: MR_P_BODY]
#901540
01/11/11 02:15 AM
01/11/11 02:15 AM
polyspheric
New York
I agree the shafts probably move, but it can't be much or something would give up. 7/16" is going to help a lot more than it sounds, it's worth doing if only to remove (or at least minimize) 1 variable. Taper is just as strong as single diameter, since the "bendy" part is mid-point (the ends could be 1/4" for the last inch without penalty).
Boffin Emeritus
[Re: sg66mopar]
#901541
01/11/11 02:25 AM
01/11/11 02:25 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
FWIW I run Manton Pushrods. They are 7/16"x.168" wall. I have about .020" deflection in mine. Lobe lift is basically the same. I also run a lot more spring. Mine are 1010 open. Also I run T&D paired rocker gear.
On my last B1 original motor I ran a 3/8" Smith Brothers pushrod with a little less lobe lift than you and say about .040"+-. I also ran the manley 850lb springs. This was with T&D common shaft rockers. Could have been the sommon shaft or maybe it was the pushrod??
Had to go check over my notes but that is what I found.
[Re: polyspheric]
#901542
01/11/11 01:34 PM
01/11/11 01:34 PM
polyspheric
New York
The single shafts are a PITA to upgrade. IIRC OD is 7/8"? The OD is far the biggest factor, but needs everything changed (stands, rockers). Comparo, with 7/8" OD with 1/8" wall as 100%: 1" OD with 1/8" wall = +57.7%
The material doesn't matter at all - moly isn't less bendy than mild steel and alum is worthless. Wall thickness is what's left, and it doesn't do much (although it's cheap and there's no down-side). You don't even really need it hardened or chromed if you have bushings (needle bearings or plain rocker ID: absolutely necessary).
Comparo, with 7/8" OD with 1/8" wall as 100%: 7/8" OD with 1/4" wall = +30.6% 7/8" OD with 3/8" wall = +35.1% Give me your wall thcikness and I'll do the math for you.
Another stand between the existing might do something, but not much room. Upsizing all the stand hardware will improve location (i.e., 5/16" > 3/8", etc.) but the heads have to be tapped, not much room in the stuff, etc. Extending all stand/cap hardware upward and using a fabricated tie-bar will do something, but the obvious problems: 1. must clear the rocker path, so tall 2. no clearance in the cover 3. must be reamed to accept stand studs
Boffin Emeritus
[Re: Al_Alguire]
#901543
01/11/11 02:01 PM
01/11/11 02:01 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
What series Manton are they?
[Re: polyspheric]
#901545
01/11/11 02:54 PM
01/11/11 02:54 PM
Posts: 1,664 North Sweden
RT540
North Sweden
Modulus of elasticity for steel is around 29, (10x6 psi) You are right, alum will bend easy 10, (10x6 psi) titanium is a little better with 15.5 A common misunderstanding, is that a molly chassi is stiffer than a mild steel, but the modulus is about the same and with thinner walls, the molly tubes will flex( bend more then the same diameter mild steel). Stretch as in permanent deformation, is what cr-mo is good for.
[Re: JD Dart]
#901547
01/11/11 08:24 PM
01/11/11 08:24 PM
Posts: 1,288 Oregon
sg66mopar
Aren’t you running the Koffles rockers arms and shafts? If so you will need spares I have a full set with spares. Looks like you will need better pushrods. I’m running .145 wall 3/8 pushrods the 7/16 would be better.
Are you looking to part with some or am I reading between the lines.
New ones are $480. At that point I'd probably step up to T&Ds.
[Re: sg66mopar]
#901548
01/12/11 04:39 AM
01/12/11 04:39 AM
Posts: 739 WA
JD Dart
WA
Sure I'll give you a stealing deal on my stuff it includes pushrods too. Went with T&D. Email me jkcomp5957@yahoo.com
