Re: Paint process QUESTION
[Re: 268RTs4ME]
#901522
01/11/11 09:16 AM
01/11/11 09:16 AM
Posts: 34 Concord Twp. Ohio
62 crown
Concord Twp. Ohio
Well, for what it's worth, I have been a PPG Paint rep for over 20 years, I collect and restore as well, so if you want to use PPG products, here's some info. Your best bet on the bare metal is DP Epoxy primer. it has excellent adhesion, and corrosion protection, and you can bondo on top of it after it cures. This will keep any moisture from getting to your bare metal during the whole restoration process, and the bondo will stick better to this product than it will to the bare metal. DEFINATELY DO NOT USE rattle can products on the bare metal first, if your foundation is weak, the rest of the money you spend on products will be wasted.... As for primer surfacer, K-36 or K-38 high build is a solid choice, there are many newer products to choose from, but these are old stand bys that work well, and won't break the bank. If you're going base/clear, Deltron basecoat (DBC) is very reliable and affordable. As for Cloearcoats, there are many options, depending on where the car will be painted, ideally, rent a spray booth that has baking capabilities, you'll be thanking yourself when the job's done. The most popular Clearcoat for a restoration in my area is DCU 2021. This stuff is easy to spray, has excellent gloss and durability, and isn't terribly hard to wetsand and buff. If the car will be a solid color, and you don't want a clearcoat, use Concept Acrylic Uretahne (DCC). This stuff is a bit tougher to deal with, but the results are awesome gloss and excellent durability. It does not buff that easy, so here agian, rent a good spray booth, or pay a professional to shoot it. It will be money well spent.. By the way, expect to spend at least a grand on paint and materials. There are other products out there that are much cheaper, but remember, you get what you pay for.... Hope this helps, and good luck, Mike
62 Imperial Crown 63 Dodge 880 67 Satellite 69Roadrunner 70Roadrunner 78 Lil Red Express 81 Powerwagon 82 Grand Wagoneer 99 RAM 2500 4X4 08 RAM 2500 4X4
[Re: 62 crown]
#901523
01/11/11 10:14 AM
01/11/11 10:14 AM
Posts: 2,634 Nashville, TN
MOPARMIKE69
Nashville, TN
Mike..... EXACTLY! This is the truth boys and girls. Been using PPG's best products for years and never had a problem. I have won first at the Nats with every car I have painted and took to show. Their best clear is expensive but I won't use anything else. PPG all the way
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: 268RTs4ME]
#901525
01/12/11 10:29 AM
01/12/11 10:29 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
I used PPG from epoxy primer through the clear. I used shop line though. Not DBC. Still cost $900.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
