Heater Box resto?
#901424
01/10/11 07:07 PM
01/10/11 07:07 PM
Posts: 2,139 New Mexico
JMCFAN
New Mexico
70RR. In process of restoring a non-AC heater box. Already ordered kit from member here How do you restor the fiberglass box? I see YO sells a kit with cleaner and spray base and top coat... anyone use it? Is there something better etc...? Also how do you reproduce the yellow part# on the metal plate?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Heater Box resto?
[Re: JMCFAN]
#901425
01/10/11 07:26 PM
01/10/11 07:26 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I simply power washed mine. Some guys power wash and then lightly clear. I did not clear mine.
As for the part number. Mine was still visable and I left it. However, I think there is a member that has the stamp or template. Maybe others will chime in.
65 Barracuda 70 Challenger
[Re: belv2vert66]
#901428
01/10/11 08:55 PM
01/10/11 08:55 PM
JMCFAN
New Mexico
No...got the blower fan off OK...little WD and a some sore fingers...
Was wondering about the brackets that are rivited on... drill them out?
The rest is all apart and have blasted ( glass bead) 1/2 of them... looking good so far
[Re: belv2vert66]
#901429
01/10/11 08:58 PM
01/10/11 08:58 PM
Posts: 22,121 Enjoy life today, It has an ex...
gtx6970
while the subject is at hand. I have a B-body non air box on the bench now. And the slotted hex head screws for the ft cover are what appear to be black phosphate,maybe zinc but they are definitly black and not silver or clear. Where as on the remainder of the assy holding the box together are clear / silver
it's out of a 67 GTX if it matters
Enjoy life today, It has an expiration date
[Re: JMCFAN]
#901430
01/10/11 08:58 PM
01/10/11 08:58 PM
JMCFAN
New Mexico
also....how did you restor your resistor plate...looks sweet!
[Re: gtx6970]
#901431
01/10/11 11:14 PM
01/10/11 11:14 PM
Posts: 1,385 Back In Iowa
belv2vert66
Back In Iowa
Bill, I can't tell what my front cover screws on the 68 box were. Too rusted. Definitely clear zinc on the rest as far as I can tell.
Mark (above post) restores an awesome box and has been very helpful to me.... I have done several but the last A body turned out well for me....
don't forget the drivers side vent...
[Re: belv2vert66]
#901432
01/11/11 08:31 AM
01/11/11 08:31 AM
gtx6970
Al, When I started taking this box apart it thought it seemed odd the front plate screws would be black , yet the screws on the back cover and the box halves were clear zinc.Otherwise it's the exact same screw in dimensions and appearence
maybe it's a year thing as this box is supposed to be from a 1967 GTX hardtop
[Re: gtx6970]
#901433
01/11/11 07:24 PM
01/11/11 07:24 PM
JMCFAN
New Mexico
I wouls also be interested in the stamp....mine is 2936681. How did you get it?
Also what paint did you use on the metal parts aftr blasting?
[Re: macmic87]
#901437
01/12/11 09:26 AM
01/12/11 09:26 AM
gtx6970
I have a local mom and pop print company make them for me. as long is it doesn't have 'artwork ' on it they usually run in the $10-$15 range .
I had a stamp made for the 69 and down voltage regulator a few months ago as an example and they were about $15 each
Ones with artwok , such as a pentastar for example ran in the $25 each range
[Re: gtx6970]
#901438
01/12/11 09:57 AM
01/12/11 09:57 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Same here, $15 at my local stamp shop for the 2837500
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: macmic87]
#901439
01/12/11 11:51 AM
01/12/11 11:51 AM
JMCFAN
New Mexico
Could you share the size and font?
[Re: macmic87]
#901441
01/12/11 12:46 PM
01/12/11 12:46 PM
JMCFAN
New Mexico
Why would mine show 2936681.... ?
