help me pick heads, hyd. cam for 440
#901007
01/10/11 12:59 PM
01/10/11 12:59 PM
Posts: 659 Regina, SK, Canada
charger
Regina, SK, Canada
hey everyone; building a street motor for a 5 speed manual.
Car is going to be street only. Goal is to have as much torque as possible to move a 68 B-body in street trim.
Shortblock is fully machined 440, forged steel crank, trw pistons, stock rods, about 10:1 with iron 346 heads.
I want to re-use an edelbrock Victor intake since I got it already, and will be using a mechanical secondary 750 holley.
So need a new cam and heads to make as much torque as possible. Need headers too so I could go with RPM's or Victor if I go edelbrock.
Car is street only, I have another race car; so torque is king. Suggestions?
Re: help me pick heads, hyd. cam for 440
[Re: charger]
#901008
01/10/11 05:15 PM
01/10/11 05:15 PM
RapidRobert
for heads 440sources' alum stealths. From what I understand they are the cheapest alum closed chamber heads available. I gathered your short block is fresh/balanced? so you wouldn't want to mill the domes any (if those TRW's have them). Have Cometic make you some head gaskets so you can get .040" quench and may be able to judiciously grind the chambers out some to adj your static CR. Dependent on your fuel/cam choice max out the dist curve and you will end up w an efficient long block
[Re: RapidRobert]
#901013
01/11/11 01:42 AM
01/11/11 01:42 AM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
the larger Summit cam at 282/292, 224/234 at .050, .465/.488 lift. 114 lobe sep.
I have one of those going into a DD 451 build & I was wondering how much (or little) personality it's gonna have. What TC will it need?
I think you could get by with a stock TC. Its smooth, like a stock factory hp cam. Maybe slightly rumpyer.
[Re: charger]
#901016
01/11/11 12:23 PM
01/11/11 12:23 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
sell the victor, buy an eddie performer RPM intake.
heads, I'd go eddies.
cam, I'd go comp XE275HL, maybe custom ground on a 112LSA, installed at 106 ICL
[Re: DaytonaTurbo]
#901017
01/11/11 02:59 PM
01/11/11 02:59 PM
charger
Regina, SK, Canada
IMO a carbed edelbrock victor intake has no place on a street only car where you say you want to build it for torq.
Just wanted to use it because I had it already.
Now are you looking for pure torq or a good balance between the two for a hot street car?
Looking for an awesome street motor; I was just making the point that I'm not going to be taking this car to the track winding it up to 7000.
because of the 5 speed, I'll probably run 4.10's with a 28" tire.
I'm not going to say budget is not a concern, it always is; but if there's a better head that fits the bill I'll go that way...so I'm not ruling the victors out
[Re: DaytonaTurbo]
#901019
01/11/11 04:20 PM
01/11/11 04:20 PM
charger
Regina, SK, Canada
I still recommend sellig the victor intake and picking something up more oriented for street use like a performer rpm.
Yeah, I just wanted to get a little more flow than the ported iron heads I'm running now; maybe I'll put on some ported RPM's and experiment with intakes... I went from a Performer RPM to Torker 2, to Victor intake and I must say on this same shortblock with a Lunati 474 cam on it and iron heads, the motor liked the victor the best.
Hey, are you from Winnipeg? I've never seen your car around...I just moved to Regina from Winnipeg.
[Re: gomangoRTSE]
#901022
01/14/11 10:44 AM
01/14/11 10:44 AM
Posts: 53 Jensen Beach, Florida
pressureangle
Low/Midrange torque=port velocity. Stealth or Eddy Performer aluminum, or a set of 451's sent to Hughes for big valves ($800) I'd use a CH4B manifold you'll have to find used; I could mash my 440/.509/850DP to the floor from idle and it took it without hesitation. Consider an aluminum flywheel-you'll lose some drivability in traffic but the difference in acceleration is stunning. With the 5-speed you won't much worry about it after you're moving and it will help with the slow shift of modern transmissions.
Why do I torture myself so?
[Re: RapidRobert]
#901023
01/14/11 10:51 AM
01/14/11 10:51 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
good cam, I ran a few. Ran 12.90 in a maybe 9:1 nothing fancy 440. (67 coronet) I used a MP 175k convert and 3.91's.
To the OP, That intake is all wrong sell it and buy a used dual palne like the CH4B or Holley SD. As for a cam, with the 5 speed you could probably get away with a little more cam. This would work well w/ a set of 3.91's or 4.10's 240/246(@ .050) 507/510 lift w/ a Lobe Separation of 110 http://www.summitracing.com/parts/CCA-21-225-4/
