RANCHO SHOCK PROBLEMS #900775
01/10/11 08:58 AM
01/10/11 08:58 AM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
I have rancho 9 position rear shocks rs 9000 x part no rs99116.
The shocks have 5/8" holes top and bottom and mopar size is 11/16".
These are the part number calvert recomends.
Has anyone had this problem.
Re: RANCHO SHOCK PROBLEMS [Re: 572B1] #900776
01/10/11 12:32 PM
01/10/11 12:32 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I believe I pressed out the metal sleeve and just ran the bushing on mine.
Re: RANCHO SHOCK PROBLEMS [Re: jbc426] #900777
01/10/11 12:36 PM
01/10/11 12:36 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: RANCHO SHOCK PROBLEMS [Re: 572B1] #900778
01/10/11 01:53 PM
01/10/11 01:53 PM
Locomotion Offline
Locomotion  Offline
I have 9114 (old 5-way) on my Dart Sport and they have the same bushing top & bottom. But you also have to look at the compressed and extended lengths for your particular application.
The Rancho website has a part #/spec page that you can compare shocks. I dont have the direct page link handy.
Rancho shocks
Re: RANCHO SHOCK PROBLEMS [Re: Locomotion] #900779
01/10/11 04:09 PM
01/10/11 04:09 PM
owt west
Thread Ender1 Offline
owt west
I went in person and told i needed CR22150 for my app.?
Re: RANCHO SHOCK PROBLEMS [Re: 572B1] #900780
01/10/11 05:16 PM
01/10/11 05:16 PM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, two things can be done to get them to fit. push the sleeve out or put shock stud in lathe and turn it down to size. on mine, there was no sleeve, I drilled the bushing out to size. just food for thought.
Re: RANCHO SHOCK PROBLEMS [Re: 572B1] #900781
01/10/11 05:27 PM
01/10/11 05:27 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have the 99116's and they bolted on my Demon with no problem.
Nautilus Racing-
Re: RANCHO SHOCK PROBLEMS [Re: jbc426] #900782
01/10/11 06:09 PM
01/10/11 06:09 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
I believe I pressed out the metal sleeve and just ran the bushing on mine. [/quote
My bushes are 5/8" and the metal sleeves are 1/2".
Re: RANCHO SHOCK PROBLEMS [Re: 572B1] #900783
01/11/11 02:09 PM
01/11/11 02:09 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If there's enough rubber to do so, remove the metal sleeve and ream the remaining rubber bushing up to the needed size.
Re: RANCHO SHOCK PROBLEMS [Re: jbc426] #900784
01/11/11 07:11 PM
01/11/11 07:11 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
We pay top dollar for made in the usa parts and nothing fits.
They can't even get a pair of shocks right.
I think next time, I order parts they will be chinese made.
What have i got to lose. rant over.
Re: RANCHO SHOCK PROBLEMS [Re: 572B1] #900785
01/11/11 07:31 PM
01/11/11 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know its not right to have to fix a new part you
spend good money on BUT you can push the inner sleeve
out and press in a larger size(correct size) but you
might to press one out of a old shock... I wouldnt
just press out the inner and run the rubber on the
bolt... you need that inner sleeve to butt against
the cross member
Re: RANCHO SHOCK PROBLEMS [Re: MR_P_BODY] #900786
01/11/11 07:40 PM
01/11/11 07:40 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
the cross member
Mr P, The old shocks are 38 years old and the bushes are rubber, with no inner sleeves.
