Neon question #900551
01/09/11 10:10 PM
01/09/11 10:10 PM
so cal,cali
calimoparguy Offline OP
so cal,cali
I havent had any car work done in a shop in a while.Whats a good price to have the water pump/timing belt replaced on an 2002 neon????thanks
Re: Neon question [Re: calimoparguy] #900552
01/09/11 10:27 PM
01/09/11 10:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Probably going to take about 4 hours, if your mechanic has done it before. It can be done a little quicker, but 4 hours is realistic. Now all you need to know is his labor rate. The pump will run about $30 and the belt will run between $30 and $50 depending on the quality you choose.
Master, again and still
