Help 2001 Caravan no go #89967
07/17/08 07:06 PM
07/17/08 07:06 PM
Sin City, AL
340wonder Offline OP
super gas
super gas
Sin City, AL
2001 Chrysler Caravan. Wouldn't turn over someone tried to jump it before I got there. Jumper cables sparking when the tried to hook them up so they quit.
Battery is fine. Cleaned the terminals on battery now all of the electrical stuff is back (light and gauges). Car won't turn over with the key. Jumping the starter and solenoid straight from the battery it turns over but won't start. Shot a little ether down the air box and it tries to hit on it.
No start and it appears it is not getting fuel. I want to think the are connected problems switch seems to be fine. Swapped around the relays in the fuse box. can hear on click when I turn the key.
Help Michael
Re: Help 2001 Caravan no go [Re: 340wonder] #89968
07/17/08 08:49 PM
07/17/08 08:49 PM
Sin City, AL
super gas
super gas
Sin City, AL
Add no spark to the list. Spare plug on plug wire gets nothing. Misting gas down throttle body gets nothing. ether it doesn't seem to like make some noise like it is dieseling.
Miss the one relay clicking under the hood I'm getting nothing. No fuel, no spark, and no starter.
Turn the switch to the on position all of the gauges come on and the dash lights light up. Turn to start hear on relay click and radio turns off everything else stays on.
Re: Help 2001 Caravan no go [Re: 340wonder] #89969
07/17/08 10:26 PM
07/17/08 10:26 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
below the battery is a junction box where the harness plugs into...check those connections and wires
Re: Help 2001 Caravan no go [Re: AARCONV] #89970
07/18/08 01:14 AM
07/18/08 01:14 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
check all the fuses , sounds like some are blown,fuel pump fuse for one,ingnition also
Re: Help 2001 Caravan no go [Re: cudaman1969] #89971
07/18/08 08:31 AM
07/18/08 08:31 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
i repaired one about 2 months ago. the battery went dead so i charged it. after the battery was charged there wasn't any power. turned out there was a blown 10amp fuse under the hood.
perception is 90% of reality
Re: Help 2001 Caravan no go [Re: AARCONV] #89972
07/18/08 10:05 AM
07/18/08 10:05 AM
Sin City, AL
super gas
super gas
Sin City, AL
We have a winner. Hole rubbed into harness and battery acid ate the copper wire of the orange wire in half.
Thank you thank you thank you.
Michael
Re: Help 2001 Caravan no go [Re: 340wonder] #89973
07/18/08 10:55 AM
07/18/08 10:55 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
send cash or 70-71 cuda parts....
Re: Help 2001 Caravan no go [Re: AARCONV] #89974
07/18/08 11:39 AM
07/18/08 11:39 AM
places
79powerwagon Offline
places
For future reference, ether and gas have NO effect on an engine if it won't crank or spark. It will wreck an engine though...
