400 stroker block preference question #898661
01/07/11 04:07 PM
01/07/11 04:07 PM
Mass
r4brightred Offline OP
Mass
If one was looking for a good 400 block for a stroker application would one out of a 72 New Yorker be a worthy candidate? Thanks.
Re: 400 stroker block preference question [Re: r4brightred] #898662
01/07/11 04:20 PM
01/07/11 04:20 PM
Maryville tn
67coronetman Offline
Maryville tn
I to have a 72 block that i got for that reason * but i have been told there is a 400 block that came in trucks that where only put out for a few months aound that time or a yrs before that was even a better foundation to start with i have not found one yet.!
Old car are me......
Re: 400 stroker block preference question [Re: r4brightred] #898663
01/07/11 05:32 PM
01/07/11 05:32 PM
AndyF Offline
AndyF  Offline
Any 400 block is a good candidate. The '72 blocks are potentially the best, but until you pass the sonic test, pressure check and magnuflux, nothing is any better than anything else.
Mopar quality control was really poor in the 70's. The blocks are all over the map in terms of wall thickness and casting quality.
Re: 400 stroker block preference question [Re: AndyF] #898664
01/08/11 10:05 AM
01/08/11 10:05 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I found a cordoba with a 400 last week in a scrap yard. I was thinking of pulling the motor and trans to just stick back in the corner for some later project. It can keep the /6, 318, 315 and 440 company. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 400 stroker block preference question [Re: rattler] #898665
01/08/11 10:52 AM
01/08/11 10:52 AM
IN
ahy Offline
ahy  Offline
IN
I used a 400 from a '78 Cordoba as a core for a 496. It worked out fine. It had the jumbo 100 amp alternator setup which I eventually wound up using as well. I am running AC with Ed heads. There just aren't many high amp alternator options with that setup.
Re: 400 stroker block preference question [Re: ahy] #898666
01/08/11 12:05 PM
01/08/11 12:05 PM
Mass
Mass
Who knows if I would ever build the thing anyway, but the price is right so maybe I will have it take up space in the basement. Thanks for the input.
Re: 400 stroker block preference question [Re: r4brightred] #898667
01/08/11 12:08 PM
01/08/11 12:08 PM
that's the story of my life
Re: 400 stroker block preference question [Re: r4brightred] #898668
01/08/11 12:25 PM
01/08/11 12:25 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Any 400 is a good starting point for a stroker. The difference with the '72 block is the main webbing is thicker.
Re: 400 stroker block preference question [Re: 451Mopar] #898669
01/08/11 07:33 PM
01/08/11 07:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
and it's only blocks cast in 71 , not sure of exact date , it's either oct or novemeber of 71
