Re: Getting to the track?
[Re: silverfish]
#898591
01/07/11 01:33 PM
01/07/11 01:33 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
34' DP MH pulling a 28' enclosed trailer
[Re: MR_P_BODY]
#898593
01/07/11 01:47 PM
01/07/11 01:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
With this to haul it... this has a sleeper on it for when I use to haul my 26' and would sleep in the truck ![](/ubbthreads/images/graemlins/wave.gif)
[Re: rickstershemi]
#898596
01/07/11 03:33 PM
01/07/11 03:33 PM
Posts: 396 California, USA
Phil Saran
California, USA
Both are good options, the LQ trailer allows you to have the truck for running errands, going out to dinner, etc.
In my case I already had the diesel truck (F350 long bed) and a 18 ft open car trailer so I added a 9'-10" cab over camper. The only problem being that it is over 8' long and that entails a HD hitch plus hitch extension that added about $500 (used) to my expenses.
My next addition is going to be a storage box on the front of the trailer since storage for a generator, small compressor, floor jack, tools is very limited with the camper.
Phil Saran
Parker, Colorado
[Re: Phil Saran]
#898597
01/07/11 03:44 PM
01/07/11 03:44 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
This works pretty good. I did install a set of airbags in the truck since this picture. A 1 ton would work good. ![](http://img808.imageshack.us/img808/7793/15544860.png) Uploaded with ImageShack.us
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#898598
01/07/11 03:58 PM
01/07/11 03:58 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
My rig. Can't say for sure how it works,,only used it locally about 6 times this year, and no overnight stays yet. Hope to give it a work out next year. It does have roof air, bathroom, fridge, stove, furnace,etc. Should be good enough for me and whoever I can talk into going with me.
If you like drag racing, support your local track.
[Re: sg66mopar]
#898605
01/07/11 06:29 PM
01/07/11 06:29 PM
CHAPPER
Belpre,Ohio
I leave the camper on my truck even when I go 35 miles to PIR for a 6 hour Wednesday night race. It only makes about 3 MPG difference and I don't have to walk a 1/8 mile to the cans 20 times a night. I'm not 25 years old anymore. ![](/ubbthreads/images/graemlins/shruggy.gif)
Plus if it's hot out it's nice to go in the camper once in a while to cool of with the AC.
My camper makes NO difference in MPG. I get 7 MPG towing, hauling, cruising,,,no matter what!!! I have found /cured a few problems to get it UP to 7!!! ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: Chassisman]
#898607
01/07/11 08:27 PM
01/07/11 08:27 PM
Posts: 28 Godfrey, Il
muntz1
Godfrey, Il
I had a 30' 96 Itasca gas motorhome and pulled a 28' trailer, it was a white nuckle ride when a tractor trailer passsed. Maybe air bags would have helped. Had to pull the waste tanks to box the frame in - the extension to the chassis from the factory was attached with a small steel plate. I just bought a used 40' aluminum exiss trailer and plan on making my own LQ's - we'll see how that goes.
[Re: muntz1]
#898608
01/07/11 08:34 PM
01/07/11 08:34 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
IMO, air bags are a must on almost ANY gas MH, and the heaviest weight dist. hitch you can get with sway control. I had some installed on a 36' gasser and it was a big improvement but still white knuckle at times. Like going over the Skyway on an extremely windy day!! ![](/ubbthreads/images/graemlins/eeek.gif)
