Confused about anti sway bars... #898160
01/06/11 08:19 PM
01/06/11 08:19 PM
Roswell, GA - near Atlanta
cloneguy Offline OP
super street
cloneguy  Offline OP
super street
This kind of thing usually happens to me just about the time I think I'm getting pretty close to knowing everything about something.
Aside from 340 Cuda's, 340 Challenger's, T/A's and AAR's, what 1970 & 1971 E bodies came stock with rear sway bars?
Were they optional on any others?
Martin, GA Quality Auto Restoration with Fair FIXED Pricing. Fast-N-Dangerous@comcast.net
Re: Confused about anti sway bars... [Re: cloneguy] #898161
01/07/11 02:39 AM
01/07/11 02:39 AM
Gig Harbor,WA
Commando66 Offline
Commando66  Offline
Gig Harbor,WA
Also available on 1976 Police A-bodies.
Re: Confused about anti sway bars... [Re: cloneguy] #898162
01/07/11 03:41 AM
01/07/11 03:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
71 R/T and 'Cuda N code 383 E-body std
70 U code 440-4bbl with 8.75 rear std.
71 V code 440-6 with 8.75 rear std.
Not sure what N code Challenger and Barracuda's got rear sway bars. Mabye the extra heavy duty suspension came with swaybars on some 2 barrel cars??? I think that extra heavy duty suspension option was cancelled at some point in 70 or 71.
Re: Confused about anti sway bars... [Re: autoxcuda] #898163
01/07/11 08:59 AM
01/07/11 08:59 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've owned three U code challengers, only one had a rear swaybar... One built without was a very late built (JS29U0B440289) with a SPD 723...
Re: Confused about anti sway bars... [Re: 1_WILD_RT] #898164
01/08/11 09:20 AM
01/08/11 09:20 AM
NY
old340dog Offline
old340dog  Offline
NY
Has anyone put a aftermarket rear sway bar on a duster340 or dart sport340? Just wondering if they are worth the money, time and effort to put one in. Is there any major improvements to handling?
old340dog
Re: Confused about anti sway bars... [Re: old340dog] #898165
01/08/11 01:05 PM
01/08/11 01:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, about three. Two different ones to the same car in fact. Two on the 68 Cuda and one on my 68 Dart vert with stock suspension. Yes, you will get a seat of the pants difference you can feel. Yes it's worth it.
This is really should be brought up in a seperate topic though.
Re: Confused about anti sway bars... [Re: 1_WILD_RT] #898166
01/08/11 01:22 PM
01/08/11 01:22 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
I have a 70 440-4 RT/SE 8-3/4 rear SPD nov69 NO rear sway bar and not coded on the Broadcast sheet
Bob
Re: Confused about anti sway bars... [Re: VCODE] #898167
01/08/11 01:25 PM
01/08/11 01:25 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have a 70 RR/SE SPD nov69 NO rear sway bar and not coded on the Broadcast sheet
Bob
Do any 70 V code get rear sway bars??? I'm not 100%all 71 V-code 8.75's got rear sways???
Re: Confused about anti sway bars... [Re: autoxcuda] #898168
01/08/11 02:05 PM
01/08/11 02:05 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
I had a 1972 Charger SE, 400 magnum, 727, 8 3/4" rear, 15X7" rallyes, with front & rear sway bars. The suspention & wheels are now making my '71 Satellite handle very well for a 40 year old car.
Re: OP - Rear sway bars on 70-71 E-bodies [Re: cloneguy] #898169
01/09/11 10:35 AM
01/09/11 10:35 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
The Rapid Transit System advertisement (1970) lists a 3/4" rear sway bar as standard on the 'Cuda.
reprinted in North, Barracuda/Challenger A Source Book, Vol. 2
As a side note, Car and Driver's test car was an early AAR that came without rear sway bar but extra stiff rear leafs to try to make up for it. Handling on the track was a handful - a lot of work for the drivers. It would seem those cars really are best with the rear sway bar package.
With the A-bodys, road racers have often found a rear sway bar unneccessary to dangerous. On a street car, there will be less body roll - which most people equate to better handling. But on the street, the tires are rarely at the limit of maximum grip. However as speed increases, or traction conditions get worse (rain) the limits of tire grip are reached. Under these conditions, the stiffer rear roll rate makes it more likely the rear tire's grip will give up before the front tire's grip. Then the rear goes past the front as you watch!
So my advice is that no matter what the car, and use the best factory package as a starting point or goal. Then make any increases to the front roll stiffness (t-bars, anti-sway bar) before increasing the rear roll rates (leafs, rear sway bar).
Re: Confused about anti sway bars... [Re: cloneguy] #898170
01/09/11 10:45 AM
01/09/11 10:45 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Two cars I have owned for decades, with factory rear bars:
> 71 Cuda 383
> 72 RR 400
Rick
Re: Confused about anti sway bars... [Re: Rick_Ehrenberg] #898171
01/09/11 10:55 AM
01/09/11 10:55 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
my 70 cuda,i think dec built has no rear bar.ive reed a bulletin somewhere(maybe the hamtramck site)that they(rear bars)where introduced "by the first of the year".
