Re: Questions on throttle stop racing...
[Re: 1976 Aspen]
#897756
01/06/11 02:25 PM
01/06/11 02:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its easier to accelerate using the lower gears VS high gear to give you the MPH (which most throttle stop cars run) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#897757
01/06/11 03:47 PM
01/06/11 03:47 PM
More outside forces can effect the car when it is coasting in high gear like headwind, friction of the track, aerodynamics of the car.
[Re: AAR-B4]
#897760
01/06/11 07:01 PM
01/06/11 07:01 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I have a friend who was pretty successful using a stop just before 3rd gear shift....really screwed with the competition too.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: bcrproducts]
#897762
01/06/11 10:39 PM
01/06/11 10:39 PM
Posts: 11,705 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It is much easier, for many reasons, to make the car competitive when using the stop early. Useful throttle stop ratios, predictability, consistency, having the RPM curve remain flat on the stop and finish line MPH, are just a few of the considerations. You have a few options. You could shift 1-2 very early on time and run the stop like the higher horsepower, 2 speed racers do (stop on, shift, stop off). The timing of these 3 events is the trick, but by running it like a 2 speed, with some adjustments, it should work fine. You could also shift the car by time or RPM a little farther out, maybe 60' or so, and then run the stop in second gear. Probably best if the car doesn't have to be slowed down quite as much. In either case, manually shifting high gear by RPM would likely be easiest if you are shifting 1-2 by time. Running the car like a 2 speed car for the first 2 gears will be the easiest to get a data base to work with. Typically the stop is on before .5-.7 out, much earlier with the big horsepower cars. Running it like a 2 speed, instead of trying to reinvent the wheel, will let you to run the car like most folks do and allow all of the advice available to be used. Expect to test and try different things before finding the sweet spot. Many factors of your car's combination will determine what it likes best. Figuring all of this out and learning how to run the index consistently, is more fun than changing the number on the window.
[Re: 1976 Aspen]
#897764
01/07/11 12:12 AM
01/07/11 12:12 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It is quite a learning curve, especially with an odd combination like yours. Expect to have to work at it. .90 racing is a lot of fun. Just expect to hear a lot of s*&# about it being boring, not real racing, ruining the sport and all the rest of it. The good racers make it look easy until you jump in.
[Re: MR_P_BODY]
#897766
01/07/11 01:31 AM
01/07/11 01:31 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Well not sure how much help it is but here goes. get the car on the stop as soon as you can and into high gear as soon as you can. Those two things should give you the consistency needed to be competitve in the sport. Now we can talk all night about finish line strategy, how much to hold, if to hold, blah blah blah.
FWIW I go 155ish on the stop at 10.90. Been 159+ but just cant seem to make that work consistently. My first number in the stop is .000, I shift at .50-.75 looking for my ideal 60' at each given track. I am off the stop in the 4.6-4-8 range depending on the weather and track conditions.
[Re: Al_Alguire]
#897767
01/07/11 11:33 AM
01/07/11 11:33 AM
Eric
Pittsburgh PA
I would have the stop come on .300 out...try setting at 3800-4200 rpm...I'm thinking in decent air you will carry 1.5 in the stop..
[Re: Al_Alguire]
#897771
01/08/11 12:30 AM
01/08/11 12:30 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
IMO the big issue is going to be the second shift from 2-3. From what I have seen with folks I have helped and talked with getting it in high gear as soon as possible is gonna be the key to consistency. You will HAVE to shift on time. IMO with a TF 1-2 should be really quick, like .5 or so but on the stop for sure. I think you will be looking at 1.8-2.0 seconds on the stop IF the car indeed can run 10.0 all out. iwoudl think shifting to high just after coming off the stop will get you what you want. Converter selection will be a big deal as well. just my
If he's running a 10.0 flat out I doubt he will be on the stop that long....I run 7.90's - 8.0's off the stop and am only on the stop for 2.6 to run 9.90 ![](/ubbthreads/images/graemlins/Twocents.gif)
Rickster
[Re: rickstershemi]
#897772
01/08/11 12:38 AM
01/08/11 12:38 AM
Al_Alguire
Las Vegas
May be but you have to admit you are charging the top end a little quicker that he will be doing. Only way to know is plug in some numbers and find out. he stated he can go 135mph which is more MPH that is needed to go 10.0. I am just guessing it is geared more for MPH, but might be wrong.
yo are probably correct that it will be less. He has to kill .90, or whatever he wants for the strategy he desires at the stripe. We all know bets way is to establish a ratio and do the math from there.
