Need 67 Barracuda clutch replacement information. #89761
07/17/08 11:30 AM
07/17/08 11:30 AM
mikemotorhead Offline OP
super street
super street
I have a 67 Barracuda Formula S 273 4 speed . It is a A-883 23 spline transmission. The car has 113,000 original miles on it and it needs a clutch. Can anyone give me some info on what to order for my mechanic to do the job? I just want a stock type easy to use in traffic clutch since my wife drives it most of the time.
Thanks Mike
Re: Need 67 Barracuda clutch replacement information. [Re: mikemotorhead] #89762
07/17/08 11:35 AM
07/17/08 11:35 AM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
What size clutch is it. if it is orig it will be a 9 1/2 clutch disk which is hard to find a good one...
If someone has "upgraded" it it should be a 10.5" which there are all kinds of options.
Any easy way to tell is if the bellhousing is cast iron (not aluminum) there is a "good" chance it is a 9.5"
Re: Need 67 Barracuda clutch replacement information. [Re: mikemotorhead] #89763
07/17/08 11:53 AM
07/17/08 11:53 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Thanks Mike
I have a local drive line shop build me 10" clutches that will bolt up on the small 9.5" wheel. More surface area on the disc.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Need 67 Barracuda clutch replacement information. [Re: 64dodge572] #89764
07/17/08 01:25 PM
07/17/08 01:25 PM
super street
super street
I am pretty sure it is all original equipment. I will have to get under there and check things out.
Thanks Mike
Re: Need 67 Barracuda clutch replacement information. [Re: mikemotorhead] #89765
07/17/08 03:21 PM
07/17/08 03:21 PM
In a town not near you.
clownzilla Offline
clownzilla  Offline
Call Brewers, they are very knowledgeable and can sell you all the right parts you need.
If you car is pure stock, you should have no problem getting a solid answer from Brewers.
If your bellhousing is different, you will need to get the numbers off of it.
The early bird gets the worm, and the second mouse always gets the cheese.
Re: Need 67 Barracuda clutch replacement information. [Re: clownzilla] #89766
07/17/08 04:35 PM
07/17/08 04:35 PM
Wis., USA
Bob_Fromm Offline
Bob_Fromm  Offline
Wis., USA
Maybe someone knows how many teeth are on a
9 1/2" flywheel. Then he could count the teeth on the flywheel he has (easy to do in the car, pull the inspection cover) and know what he has....
Re: Need 67 Barracuda clutch replacement information. [Re: Bob_Fromm] #89767
07/17/08 04:38 PM
07/17/08 04:38 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
9.5" wheel should be 122T
FAX 937-947-4419
