Broadcast Sheet -wheel code question #897122
01/05/11 08:44 PM
01/05/11 08:44 PM
Berks County, PA
V0B Cuda Offline OP
V0B Cuda  Offline OP
Berks County, PA
Hi everyone,
I have a question about the Broadcast sheet for my 70 Cuda. On line 4 under the wheels heading. In the "road" box I can't make out the number, in the "color" box it has K2, "spare" box #81. Under wheel cover box #88. I think #81 is space saver, is the wheel color vitamin "c" ? What does #88 mean under wheel cover? Thanks for any help.
Vitamin C-1970 Cuda 440-6 {since 1978}
Re: Broadcast Sheet -wheel code question [Re: V0B Cuda] #897123
01/05/11 09:12 PM
01/05/11 09:12 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
WHEEL COVER 88 is #2911 088 (the "PLYMOUTH DIVISION" stainless steel hub cap)
If your car had 15" wheels & E60-15 tires originally the b'cast sheet will show:
WHEELS/ROAD - 28 - 15x7.0" steel wheels
COLOR - EK2 - painted "vitamin C"
SPARE - 81 - 14x5.5" space saver wheel & tire
If your car had 14" wheels & F70-14 tires originally the b'cast sheet will show:
WHEELS/ROAD - 17 - 14x6.0" steel wheels
SPARE - 81 - 14x5.5" space saver wheel &tire
Re: Broadcast Sheet -wheel code question [Re: 6bblgt] #897124
01/05/11 11:58 PM
01/05/11 11:58 PM
Berks County, PA
V0B Cuda Offline OP
V0B Cuda  Offline OP
Berks County, PA
6BBLGT, thanks for the response, the original tire code is U82 E60X15 polyglas and you're right the color code is EK2 not K2.
Re: Broadcast Sheet -wheel code question [Re: V0B Cuda] #897125
01/06/11 01:07 AM
01/06/11 01:07 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
For '70 there were approximately 1537 big block (BS23-N/U/V) 'Cudas with E60-15s (US spec.).
