herbert solid flat tappet cams?
#896718
01/05/11 02:12 PM
01/05/11 02:12 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
anyone run herbert solid flat tappet cams in their big block? i am going to do a cam swap down the road and these cams fit my tight budget at 99.00! im curious who has one and what do you think about it? thanks!
Re: herbert solid cams?
[Re: shoebox]
#896719
01/05/11 02:31 PM
01/05/11 02:31 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have a doug herbert solid roller in mine but its old school. Seems to work ok but im sure there are better grinds then mine. Are you talking roller? If so where are you finding them?
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#896720
01/05/11 02:36 PM
01/05/11 02:36 PM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
Google "Doug Herbert Performance" in Lincolnton,NC. That's Chet Herbert's son Doug, the same NHRA nitro Doug.
[Re: Bighead440]
#896721
01/05/11 02:50 PM
01/05/11 02:50 PM
dragram440
bigfork mn
Doug herbert doesnt list any solid roller cams for big block mopars that I can find!!
67' charger 499 RB
10.57 at 127
[Re: Labratt]
#896727
01/05/11 07:04 PM
01/05/11 07:04 PM
Everytime a customer shows up with Herbert cam box we know it will be down on power vs. just about anything else--all of my experience has been with Herbert rollers but man! I don't care what the specs say--they are not a good choice IMO. The Summit #6401 Hyd for BB is a cheapo and a fantastic cam for street applications. For a solid I would save my $$ and get a good known cam from a good engine shop--get help picking it out so you have a good combo.
[Re: 6PACMAC]
#896729
01/06/11 01:39 AM
01/06/11 01:39 AM
shoebox
mckinney texas
I've got the .600 lift, 270 at 050 solid cam sitting on a shelf. Actual lift worked out to .583-.585 ish. I don't recall the actual .050 dur numbers. But, Its was cheap, like $49 25 years ago. At that time I went with the mopar 590 cam. I'll stick the Herbert in something some day.
thats the grind i was told about! i started this thread because i really couldnt find any mention anywhere about their solid flat tappets. everyone has their cheaper roller cams. which arent that cheap anymore. 259for the cam and 3somthing for the lifters
[Re: shoebox]
#896730
01/06/11 11:52 PM
01/06/11 11:52 PM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
Go to dougherbert.com. They still make that cam. HERCD5X is the model#. It's $99 bucks for the cam. Still pretty cheap
[Re: 6PACMAC]
#896731
01/07/11 02:20 PM
01/07/11 02:20 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
my cam is a herbert cam ground by rubin racing cams rubin does all there cam grinding now ,try these specs out for a lazzy cam solid roller .020 ..304 /312 .050...270/277 lobe lift 450/420 .200..190/195 you can tell rubin that ian from australia sent you there ,he will give you a great price, phone 7144912267
