Source for convertible rear glass?? #896639
01/05/11 11:09 AM
01/05/11 11:09 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
My original piece of Glass for conv.top on My '67
GTX has deep scratches,so Folks redoing Top say
Glass will probably break when They attempt to
install new material around Glass.ECS can't get
new Glass for convertible..Any suggestions as to
where I can get new Glass ???
Re: Source for convertible rear glass?? [Re: gassy66] #896640
01/05/11 01:33 PM
01/05/11 01:33 PM
South Lyon, Michigan
6bblRoadrunner Offline
Re: Source for convertible rear glass?? [Re: gassy66] #896641
01/05/11 01:41 PM
01/05/11 01:41 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If you are using a new top kit from a vendor, they should have given you the option for either a plastic window or glass.
If not, and the glass is a flat sheet, you can go to a good windshield/glass shop with the old piece and have them cut a window for you from stock safety material (shatter-proof). They should also be able to get it in clear or tinted.
Hope that helps.
Mo' Farts
Moderated by "tbagger".
