Parts for my 68 Charger #896599
01/05/11 04:50 AM
01/05/11 04:50 AM
Stockholm, Sweden
MrSixpack Offline OP
Stockholm, Sweden
I have a rather unik 68 Charger.
It has a slant6 and three on the tree, and the car is almost done after a total resoration.
But I need parts(overhaul kit) for my column shifter, it's so sloppy that I can get it stuck in both revers and first gear at the same time.
And I would like not to use a floor shifter but the original column shifter.
Can I get parts for it??
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Parts for my 68 Charger [Re: MrSixpack] #896600
01/07/11 12:37 PM
01/07/11 12:37 PM
Stockholm, Sweden
Stockholm, Sweden
No one ever rebuilt a column shifter
I don't like to put a floorshifter in it
1968 Mini Cooper
Re: Parts for my 68 Charger [Re: MrSixpack] #896601
01/07/11 01:56 PM
01/07/11 01:56 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I am sorry I can't be of any assistance, but I just wanted to say that is one very cool car you have there!
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: Parts for my 68 Charger [Re: sycboi] #896602
01/07/11 09:43 PM
01/07/11 09:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Could be just bushings. If it doesn't use bushings look for holes that have become oval. Hopefully there's an exploded drawing of it in the factory service manual and you can see what the wear points are.
Could also be the rods or levers are bent, or there might be adjustments you can make.
Re: Parts for my 68 Charger [Re: topside] #896603
01/10/11 11:28 AM
01/10/11 11:28 AM
Stockholm, Sweden
Stockholm, Sweden
Thanks for your help
The slop in my case is in the steering column, not the linkage or bushings.
I will take it apart once again and see if I can fix it, I have a lathe so it's just some more work i guess.
1968 Mini Cooper
