Steering box support ????????
#896123
01/04/11 03:24 PM
01/04/11 03:24 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
OK, I have what I think is enough cut off the drivers side mount to allow clearance for the oil lines.
I left as much of the original structure as I could and it looks like it would be strong enough to support the gear box as it is now.
I wont know for sure till Dad gets here after work tonight and if I have to cut more out I know it will need reinforced but I'd like to hear your thoughts on how it stands now.
If I leave it like this do you think there will be a problem?
Re: Steering box support ????????
[Re: Thumperdart]
#896125
01/04/11 04:19 PM
01/04/11 04:19 PM
WILD BILL
BROOK PARK, OH
Good to hear.
My car is race only so it wont have the punishment of street cornering.
[Re: WILD BILL]
#896126
01/04/11 09:29 PM
01/04/11 09:29 PM
WILD BILL
BROOK PARK, OH
Well, so far so good.
Dropped the motor down in and I have plenty of room for all the lines now.
I do need to change out the one end on the rear line to a 45* fitting though.
Anyone else have any thoughts on the gear box mount?
[Re: blownzoom440]
#896128
01/04/11 10:01 PM
01/04/11 10:01 PM
WILD BILL
BROOK PARK, OH
Motor is not in the car now Mike.
Not ready to be able to leave t in just yet.
I will say though that snaking the motor plate thought the bars and into place is a lot easier than I thought it would be.
[Re: WILD BILL]
#896129
01/05/11 12:15 AM
01/05/11 12:15 AM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
You left more of the mount than I did Bill. Of course, the steering box is of no use for the first 60' anyway. (see below) Brian Dunnigan
[Re: Sixpak]
#896131
01/05/11 06:11 AM
01/05/11 06:11 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Id brace it. You'd be amazed how much that mount will flex, especially in a panic countersteer slide. It should only take about 5 minutes if you have a welder, so there's no reason not to IMHO.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: sg66mopar]
#896133
01/05/11 01:44 PM
01/05/11 01:44 PM
WILD BILL
BROOK PARK, OH
I've never seen a pic but I don't think I was yanking em any higher than what your sig pic looks like.
Then again, this motor does have more torgue so who really knows.
If I try rotating the front oil line any more my lower radiator hose wont go on.
I do have a 4 link so I should be able to adjust em so that I don''t pull the front to high right?
I'ld much rather keep em down and shoot out like a rocket than put the nose in the sky.
