Block heater ???? #895656
01/03/11 08:53 PM
01/03/11 08:53 PM
La Grange, Ky
70rrclone Offline OP
La Grange, Ky
i finally got the 440 installed in the car, now i can't seem to keep the block heater from blowing out of the block. all i have to do is rev it up a few times and out it comes. are block heaters one time use? i took this one out of the 360 i pulled out. any ideas????
thanks
Shane
Re: Block heater ???? [Re: 70rrclone] #895657
01/03/11 08:58 PM
01/03/11 08:58 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
well core plugs are one time use, so I'd suppose the heater plug is the same way. Try flaring the lip on the plug and install with some #1 hardening permatex, then let dry good.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Block heater ???? [Re: 70rrclone] #895658
01/03/11 09:01 PM
01/03/11 09:01 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Never heard of one falling out. Does it have the v-shaped part on the backside that snugs up against the inside of the block to hold it in place when you tighten the bolt? Maybe the v-shape part doesn't contact the block properly allowing it to slide out?
Having heard stories of the freeze plug style heaters weeping antifreeze I went with a heater that fits into the lower radiator hose instead.
I bought one from NAPA that looks just like this one.
http://www.amazon.com/Kats-14800-Lower-Radiator-Heater/dp/compatibility-chart/B000I8XD3K
Re: Block heater ???? [Re: 70rrclone] #895659
01/03/11 09:01 PM
01/03/11 09:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Get a good block heater. Not one that expands to hold in. Get one that has the cross bar that goes across the inside of the block core hole and tightens up with a screw. They have o'ring around the outside. Never had a problem with one of them tha is like this. Notice the btterfly bat on the back side on this pic.
Re: Block heater ???? [Re: MoparforLife] #895660
01/03/11 09:05 PM
01/03/11 09:05 PM
La Grange, Ky
La Grange, Ky
attached is a pic of the one i currently have.
moparforlife.... your pic didn't show up the first time i looked..... but that looks like the one i have.
Re: Block heater ???? [Re: 70rrclone] #895661
01/03/11 09:45 PM
01/03/11 09:45 PM
Upper Midwest
Upper Midwest
That cross bar should be tightening up across the inside of the block not allowing it to pop out.
