Block heater ????
#895656
01/03/11 08:53 PM
01/03/11 08:53 PM
Posts: 1,323 La Grange, Ky
70rrclone
La Grange, Ky
i finally got the 440 installed in the car, now i can't seem to keep the block heater from blowing out of the block. all i have to do is rev it up a few times and out it comes. are block heaters one time use? i took this one out of the 360 i pulled out. any ideas????
thanks Shane
Re: Block heater ????
[Re: 70rrclone]
#895658
01/03/11 09:01 PM
01/03/11 09:01 PM
Posts: 20,764 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Never heard of one falling out. Does it have the v-shaped part on the backside that snugs up against the inside of the block to hold it in place when you tighten the bolt? Maybe the v-shape part doesn't contact the block properly allowing it to slide out? Having heard stories of the freeze plug style heaters weeping antifreeze I went with a heater that fits into the lower radiator hose instead. I bought one from NAPA that looks just like this one. http://www.amazon.com/Kats-14800-Lower-Radiator-Heater/dp/compatibility-chart/B000I8XD3K
[Re: MoparforLife]
#895660
01/03/11 09:05 PM
01/03/11 09:05 PM
70rrclone
La Grange, Ky
attached is a pic of the one i currently have.
moparforlife.... your pic didn't show up the first time i looked..... but that looks like the one i have.
