Re: 1998 ram 5.2 will 1.6 rockers wake it up?
[Re: drifter]
#895161
01/03/11 02:46 AM
01/03/11 02:46 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
well..the stock rocker ratio on a magnum is 1.6
so you are already there..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#895162
01/03/11 07:38 AM
01/03/11 07:38 AM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
Everyone steps up to the 1.7:1 on the Magnum engines, as "1.6:1" are factory/stock.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
[Re: 70AARcuda]
#895163
01/03/11 08:01 AM
01/03/11 08:01 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
To answer the posters question- Dyno results have shown modest gains going to aftermarket 1.6 roller rockers (5-10 hp)
Myself would not waste the funds ($300) for the hp gain. I had 1.7's on my Durango and only noted modest gains and then over 4500 rpm.
Hope this helps.
[Re: gdonovan]
#895165
01/03/11 10:22 AM
01/03/11 10:22 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Hope this helps.
I think the biggest problem w/ the Magnum engines is the intake. That thing is done at 4800-5k tops. If you spend money get an intake the works. When I re-do my 95 Dakota I will be gong w/ a M-1.
[Re: Mr.Yuck]
#895166
01/03/11 11:25 AM
01/03/11 11:25 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
get the cam reground by bullet cams, using their HR259/316 lobe for both the intake and exhaust. use hughes #1110 springs, and their retainers.
on the cheap, cut the runners in the intake down about 2" internally, on the not so cheap, go with the hughes/edelbrock RPM air gap conversion.
