new race motor oil #895154
01/03/11 12:53 AM
01/03/11 12:53 AM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
just built a race motor with 2.2 on rods and 3 on mains.steel rods and heads..will be running 20w50 oil ,,question is after i fire it up with that oil should i change it before racing or go with it to the track ??? thanks
Re: new race motor oil [Re: Plymouth340] #895155
01/03/11 01:04 AM
01/03/11 01:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What cam and do you have added zinc in the oil
Re: new race motor oil [Re: MR_P_BODY] #895156
01/03/11 01:09 AM
01/03/11 01:09 AM
CEDAR RAPIDS
CEDAR RAPIDS
solid roller and valvaline oil
Re: new race motor oil [Re: Plymouth340] #895157
01/03/11 01:39 AM
01/03/11 01:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When I do a rebuild on mine(solid roller) I fire it
up and set the timing and idle then go to the track
and BEAT on it for the weekend then change the oil...
I dont know if you will need that heavy of weight oil
but check your pressure when its up to temp to see
what you have and if YOUR happy with it... I dont
like mine under 20psi after a full pass and I adjust
the weight of oil to it
