318 oil pressure?? problem #895090
01/02/11 11:19 PM
01/02/11 11:19 PM
New Richmond, WI
K
kams Offline OP
kams  Offline OP
K
New Richmond, WI
I have a 88 dakota with a 318 501 comp cam, 360 heads, weiand intake, the rest is stock parts, .030 cast piston.
Its has about 50lbs. when cold and when warmed up it just above the 0 on the gauge. The rocker are a little loose so the rockers make some noise.
What could be the problem?
Re: 318 oil pressure?? problem [Re: kams] #895091
01/02/11 11:26 PM
01/02/11 11:26 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
excessive bearing clearances
Re: 318 oil pressure?? problem [Re: kams] #895092
01/02/11 11:29 PM
01/02/11 11:29 PM
When did it start? Any recent work/changes right b 4 it started acting up?
Re: 318 oil pressure?? problem [Re: RapidRobert] #895093
01/03/11 10:11 AM
01/03/11 10:11 AM
scratchnfotraction Offline
electric gauge? mech gauge?
rule the gauge out first IMO
Re: 318 oil pressure?? problem [Re: kams] #895094
01/03/11 11:46 PM
01/03/11 11:46 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
There's a threaded plug in the drivers side of the lifter valley behind the last lifter. If it is missing you will have low oil pressure for sure.
Re: 318 oil pressure?? problem [Re: JeffC] #895095
01/04/11 12:06 AM
01/04/11 12:06 AM
If you have (actually) near zero the lifters will be clattering like hell
Re: 318 oil pressure?? problem [Re: RapidRobert] #895096
01/04/11 08:45 AM
01/04/11 08:45 AM
should rattle with near 0 psi
