roll cage specs
#894983
01/02/11 09:56 PM
01/02/11 09:56 PM
Posts: 12,080 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Getting ready to have a cage put in the Dart and I don't know a thing about what I need to tell the guy. He's a buddy that doesn't normally do drag stuff, mostly roundy-rounders. But if I get him the specs, he will do it up.
So, where should I go to get the condensed version of requirements for a 10 sec. car? And for that matter, I guess I may as well get all the rules for the car to pass inspection.
I am not sure that it will ever see a sanctioned track (our local track isn't sanctioned), but I thought that I would get the bigger, more difficult things out of the way.
Thank you!
Master, again and still
Re: roll cage specs
[Re: DaveRS23]
#894984
01/02/11 10:20 PM
01/02/11 10:20 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
A 6 point roll bar is good until 9.99 or faster. 1 3/4 .134 MS EWS is fine. It needs to be welded directly to the frame or 6x6 plates. You can buy a basic prebent *kit* from S&W race cars for $189.00. NHRA rule books have the drawings and tubing thickness's. here i just found this: http://www.nhraonline.com/contacts/tech_faq.html
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: roll cage specs
[Re: DaveRS23]
#894985
01/02/11 11:08 PM
01/02/11 11:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Once you go 9.99 or quicker is when you need a full cage and thats when you need to have it certified (and alot of added safety equipment)
