Comp 829 roller lifter-Oil soak before spring? #894880
01/02/11 07:13 PM
01/02/11 07:13 PM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
For you guys with non-pressure fed roller lifters. Do you guys soak them in oil after winter storage before start up or does pre-oiling and remaining oil cover it?
Mines a street only piece with 3000K on them so far. I haven't seen anything that would indicate they need a check, but it has been sitting since Nov and won't be re-started until mid-late April.
Re: Comp 829 roller lifter-Oil soak before spring? [Re: torkrules] #894881
01/02/11 08:34 PM
01/02/11 08:34 PM
Did you do any "winterizing before parking it? Either way pulling the distributor and priming the oil system and then turning the motor over, with the spark plugs removed, on the starter while priming it can't hurt
Re: Comp 829 roller lifter-Oil soak before spring? [Re: Cab_Burge] #894882
01/02/11 08:46 PM
01/02/11 08:46 PM
I'm neurotic
I'm neurotic
Only winterizing I did was to pull the plugs and spray some storage oil down the cylinders. 50/50 mix of anti freeze in a dry and relatively warm (doesn't get bellow 32 degrees).
Don't want to pull the intake unless it's necessary.
Re: Comp 829 roller lifter-Oil soak before spring? [Re: torkrules] #894883
01/02/11 10:21 PM
01/02/11 10:21 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Aren't you firing it up once in a while John? Give me a call this week, I'm back staring tomorrow.
Steve
Photobucket sucks
Re: Comp 829 roller lifter-Oil soak before spring? [Re: 72chrgrally] #894884
01/02/11 10:25 PM
01/02/11 10:25 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Dont worry about them. They would need less oil than a standard lifter, seeing how they a re needle bearing style.
Is the lifters bushed? Just prime the engine in the spring
